Old 12-10-2005, 07:09 PM   #1 (permalink)
champ_rock
champ_rock's Avatar
Default LOW Specs
which disro would u recommend for me... linux newbie
450mhz p-3
128mb ram
40gb hdd
cd writer
dvd player
intel motherboard
Registered Linux user number 400618
champ_rock is offline
Old 12-10-2005, 09:38 PM   #2 (permalink)
I feel ur sys would be a bit slow if u want Gnome or KDE since u have 128 MB Ram.
Million's Of Open Minds Can't Be Wrong!
http://nc.xmgfree.com/weblog
Everybody Wants to go to Heaven...But nobody wants to Die!
naveenchandran is offline
Old 13-10-2005, 10:04 AM   #3 (permalink)
champ_rock
champ_rock's Avatar
i think ubuntu runs fine on my system....... but there is a lot of trouble with ubuntu..... i am not able to play music even .. after a lt of trouble......
Old 13-10-2005, 12:13 PM   #4 (permalink)
Any distribution will run fine on your system, although you may have to change the desktop environment used. Most popular distributions come with Gnome or KDE, which, although they will run, will perform quite sluggishly. You can replace them with a lighter desktop/window manager like XFCE, IceWM to get better speed.
Vector Linux is a great distribution which will run like a breeze on your system, out of the box. It comes with XFCE and other window managers, and is optimised for older PC's.
By the way, there have been many other discussions on the same topic earlier, search this forum and you will find a lot of information.
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
ujjwal is offline
Old 13-10-2005, 01:03 PM   #5 (permalink)
Wire muncher!
infra_red_dude's Avatar
try "damn small linux" comes wid windowmaker. light on sys resources. lets u play mp3s too!
infra_red_dude is offline
Old 13-10-2005, 05:39 PM   #6 (permalink)
left this forum longback
praka123's Avatar
get rh7.2 or 7.3 (li'l old) that will do if u want sound to work :roll:
praka123 is offline
Old 13-10-2005, 06:04 PM   #7 (permalink)
desertwind's Avatar
Any linux distro will run fine in ur system if u use some less resource hungry window managers like
IceWM
Blackbox
FVWM
etc.
Probably GNOME and KDE will be a bit sluggish.
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
Old 13-10-2005, 07:25 PM   #8 (permalink)
champ_rock
champ_rock's Avatar
hey desert can i do with fc4.........
Old 13-10-2005, 09:37 PM   #9 (permalink)
desertwind's Avatar
Sure. I've installed FC4 on many of my friends machine with P3 and 128 MB RAM. The only thing is that dont go for gnome or kde. you can install and work, but that would be a real effort, and needs a lot of patience.
