Old 08-10-2005, 07:58 PM   #1 (permalink)
champ_rock
champ_rock's Avatar
Default MP3 trouble
hi
i installed ubuntu linux.... but when i try to play mp3 songs from cd it shows an error.. i am using totem.... what should i do
champ_rock is offline
Old 08-10-2005, 08:49 PM   #2 (permalink)
desertwind's Avatar
you may be using totem-gstreamer. you'll need mp3 support for gstreamer.
$ apt-get install gstreamer-plugins-mp3
or install totem-xine
$ apt-get install totem-xine
But i havent used totem for playing mp3 (its much a movie player, even i never used totem for playing movies, either). For playing mp3 i'll suggest u using xmms or rhythmbox.
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
Old 08-10-2005, 11:56 PM   #3 (permalink)
use amarok if u use ubuntu. Try to download and use xmms which is so similar to winamp and u can play mp3 easily.
Hibernating ....
banned2wise is offline
Old 09-10-2005, 09:16 AM   #4 (permalink)
vignesh's Avatar
beep is good to ,no extra dependencies and only 980 kb similar to xmms and supports both winamp and xmms skins.
http://packages.debian.org/stable/so...p-media-player
vignesh is offline
Old 12-10-2005, 07:06 PM   #5 (permalink)
champ_rock
champ_rock's Avatar
hey guys a lot of trouble..........
i have installed xmms after a series of dependies....
now it is installed but whe n i run it it says install gtk....
i have got gtk + instaled and a lot of dependies of gtk also and when i try to install gtk from synaptic it says version indetermined and it simply does not insatll gtk...
when i use beep ... only it says that it is playing the music but no sound comes... and afetr ssome time it hangs up
for more details .. please see
http://www.linuxforums.org/forum/topic-57596.html
Registered Linux user number 400618
Old 12-10-2005, 08:47 PM   #6 (permalink)
vignesh's Avatar
Change the ouput plugin to esd.
vignesh is offline
Old 13-10-2005, 09:28 AM   #7 (permalink)
champ_rock
champ_rock's Avatar
tried alsa esd everyhting///////////
still same prob
Old 13-10-2005, 09:47 AM   #8 (permalink)
champ_rock
champ_rock's Avatar
ok desertwind
i have set up totem-xine and the apt get has removed my totem gstreamer..........
but now it asks for some
Audio codec 'MPEG 1 Layer 3 CBR' is not handled. You might need to install additional plugins to be able to play some types of movies
... what should i do.... also whether totemxne will run automatically when i run totem movie player.....
Old 13-10-2005, 07:39 PM   #9 (permalink)
vignesh's Avatar
Is your soundcard detected.So to system->preferences->multimedia selector and try changing them by testing.
vignesh is offline
Old 13-10-2005, 08:50 PM   #10 (permalink)
champ_rock
champ_rock's Avatar
yeah ubuntu plays the basic system sounds... on atartup and little clicks and all tyhat so the sounds cad is detected.....
Old 14-10-2005, 06:25 PM   #11 (permalink)
vignesh's Avatar
Then install beep media player esd plugin.Or download xmms or other player from
packages.ubuntu.com
vignesh is offline
Old 15-10-2005, 05:05 PM   #12 (permalink)
champ_rock
champ_rock's Avatar
done that too... thanks for ur help ... i have dumped ubuntu and installed fc4 ...
Old 15-10-2005, 05:58 PM   #13 (permalink)
vignesh's Avatar
Even FC4 does not support mp3 y default....
vignesh is offline
Old 15-10-2005, 10:15 PM   #14 (permalink)
champ_rock
champ_rock's Avatar
yeah already experiinced it and forund that we need some extrtra plugins... wahts the red hat substitute for apt-get....
and how do i use it...
Old 15-10-2005, 11:22 PM   #15 (permalink)
desertwind's Avatar
for adding mp3 support in FC4 just use the command
$ yum install gstreamer-plugins-mp3
Old 16-10-2005, 12:03 AM   #16 (permalink)
left this forum longback
praka123's Avatar
yum is a waste thing,better try apt4rpm ,OR get rpms downloaded and installed manually from sites
like rpms.livna.org or dag's site. u can even get wma plugins for xmms there
praka123 is offline
Old 16-10-2005, 04:11 PM   #17 (permalink)
vignesh's Avatar
Download it from livna but don`t forget the dependencies
vignesh is offline
