| Forum |
#1 (permalink) |
Error 1: rhythmbox Code:
From root@localhost.localdomain Tue Oct 4 01:05:02 2005 Date: Tue, 4 Oct 2005 01:05:02 +0530 From: root@localhost.localdomain (Cron Daemon) To: root@localhost.localdomain Subject: Cron <root@localhost> rhythmbox X-Cron-Env: <SHELL=/bin/bash> X-Cron-Env: <PATH=/sbin:/bin:/usr/sbin:/usr/bin> X-Cron-Env: <MAILTO=root> X-Cron-Env: <HOME=/> X-Cron-Env: <LOGNAME=root> X-Cron-Env: <USER=root> (rhythmbox:9435): Gtk-WARNING **: cannot open display: Code:
From root@localhost.localdomain Tue Oct 4 01:06:03 2005 Date: Tue, 4 Oct 2005 01:06:03 +0530 From: root@localhost.localdomain (Cron Daemon) To: root@localhost.localdomain Subject: Cron <root@localhost> bittorrent X-Cron-Env: <SHELL=/bin/bash> X-Cron-Env: <PATH=/sbin:/bin:/usr/sbin:/usr/bin> X-Cron-Env: <MAILTO=root> X-Cron-Env: <HOME=/> X-Cron-Env: <LOGNAME=root> X-Cron-Env: <USER=root> Traceback (most recent call last): File "/usr/bin/bittorrent", line 32, in ? import gtk File "/usr/lib/python2.4/site-packages/PIL/__init__.py", line 37, in ? RuntimeError: could not open display
Sometime you'll think you understand everything ...Then you'll regain consciousness |
#3 (permalink) | |
firewall is correct. cron will most probably run GUI apps. btw i hv my doubts with this thing
#4 (permalink) |
i've created the cron job as root
logged in as root and trying to run the app as root. Is that the real problem ?
#6 (permalink) |
FooBar Guy
Its actually possible to run GUI application from cron.
1) The user who is running X should allow X authentication from all users by giving: $ xhost + 2) The cron script should know on which X display to draw the application by: $ export DISPLAY=:0.0 Now this will work for GUI applications started from all users.
- -- http://www.MovieAB.com - A tiny movie mashup! |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
