Old 30-09-2004, 04:19 PM   #1 (permalink)
Default Linux kernel compilation problem ..
Hi all,
My distro is Fedora Core 1 with kernel 2.4.22-1.2115.nptl
while making bzImage during its final stage it gives the following error
kernel.o(0xfc3) .. I function schedule() undefined reference to active_load_balance
Error 2
aborting ...
and it gets out .. whats wrong ... while makeing xconfig ..i`ve loaded the previous config file from /boot and added support to ntfs file partition . thatz the only change that i have made when comparing with the old file ... is that wrong ...? y it happens like that
neo_the_one is offline
Old 30-09-2004, 07:18 PM   #2 (permalink)
firewall's Avatar
check this link... it will help u..
http://linuxjunkies.org/forum/viewtopic.php?t=185
www.aloke.info
firewall is offline
Old 01-10-2004, 07:15 PM   #3 (permalink)
FooBar Guy
GNUrag's Avatar
If it gets compiled nicely then it shouldn't cause any trouble while making images.... did you try to make a GzImage instead ? what file from /boot are you referring to ?
btw: check out firewall's site , that's a good article on kernel compilation...
http://web.gnuer.org
GNUrag is offline
