Old 30-09-2005, 07:31 PM   #1 (permalink)
tech_cheetah's Avatar
Default Sudokool on linux - plz help me
hi friends
I have developed a game in java which is based on the popular sudoku puzzles.
preview
U can view more information about the game in the thread
here
Now the problem is that the game runs only in windows.
The main game file is an executable jar file.So double click on the file opens the game.
But in linux the jar files gets opened and shows the archived class files.
So plz help me ,how can i make the game run in linux ?
I cannot use applet bcoz the game interacts with the local files for saving records.
Moreover the java files are not compiling in linux.
I have recently installed FC4.When i try to compile java files on terminal,it gives the following warning (in case of inheritance)
eg.
class now extends JFrame
$javac now.java
Warning: The serializable class now does not declare a static final serialVersionUID field of type long
However the same file works perfectly well when run on Windows.The JVM on FC4 is 1.4.2 and even though i have installed the latest version of gcc(4.0.1)the problem still persists
Plz help me....[/url]
tech_cheetah is offline
Old 01-10-2005, 03:26 PM   #2 (permalink)
desertwind's Avatar
Oh! Its working on my FC4 Box.
i just gave the command
java -jar Sudokool.jar
Well. but theres seems a problem for me. No numbers at all. all i see is some dots all over.
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
Old 01-10-2005, 07:45 PM   #3 (permalink)
which jre are u using on ur FC4?
I mean u seem to have upgraded the default jre1.4 to jre1.5.
if so plz tell me the source ie. rpm,or source ,better give me the link.
Well i think the problem lies in the layout manager of java in linux.
The same problem occured when i gave wrong size to buttons in windows.
Be honest . By that way u can be sure that the world is short of atleast one rascal.
Old 01-10-2005, 07:50 PM   #4 (permalink)
desertwind's Avatar
i use jre1.5.0 update 5. No, i havent upgraded, it was a fresh install.
Downloaded it from java.sun.com
Old 01-10-2005, 07:57 PM   #5 (permalink)
The problem might have solved if i had given resizing option.But i didn't give it to avoid any improper layout of buttons on resizing window.
Why don't u try to change resolution of ur screen.
Old 01-10-2005, 10:40 PM   #6 (permalink)
desertwind's Avatar
I'm already on 1024x768. Do i need more resolution ?
Old 02-10-2005, 08:08 PM   #7 (permalink)
no ,what i meant was that u change ur resolution... since u r now at 1024x768 plz try 800x600 ... may be that bring some change in the layout.
Old 02-10-2005, 08:49 PM   #8 (permalink)
I am getting this message when i use java -jar Sudokool.jar
Invalid or corrupt jarfile Sudokool.jar
I am using jre1.4.2
Let the windows open and the penguins come in.
Regards,
Sanket Medhi.
e-freak is offline
Old 02-10-2005, 11:22 PM   #9 (permalink)
desertwind's Avatar
@e-freak: He has clearly mentioned here that this one will work smoothly on jre 1.5.0. Try using it.
@tech_cheetah: I tried 800x600, but still it doesnt seems to work. still shows some dots instead of numbers
Old 03-10-2005, 10:14 AM   #10 (permalink)
So much for platform independent!
Regards,
Sanket Medhi.
e-freak is offline
Old 03-10-2005, 06:21 PM   #11 (permalink)
There might be some problem during downloading due to which the jar file got corrupted.I advise e-freak to download again.
desertwind : u r right.. we should blame Sun for the so-called platform independent technology... we can clearly c the difference in the GUI in windows and in linux. So now i will have to optimise and recompile the game for linux
Old 04-10-2005, 02:11 AM   #12 (permalink)
I use Blackdown Java JRE as well as JDK. It gives me the plugin for my AMD 64 system!
Regards,
Sanket Medhi.
e-freak is offline
Old 04-10-2005, 02:15 AM   #13 (permalink)
Ok now I tried the file on Windoze and WinRaR gives me an error while extracting itself! Tech_cheetah, please check the file on the link and get back.
Regards,
Sanket Medhi.
e-freak is offline
Old 05-10-2005, 03:14 PM   #14 (permalink)
here
u will get the exe file,which is a self extracting archive.
Old 05-10-2005, 11:02 PM   #15 (permalink)
Uhh... I cant really say when I will have to (unfortunately) boot into Windoze...so please give me a link to the jar file as it is.
Regards,
Sanket Medhi.
e-freak is offline
Old 06-10-2005, 01:30 PM   #16 (permalink)
FooBar Guy
GNUrag's Avatar
heh, Maybe at your college
http://www.MovieAB.com - A tiny movie mashup!
GNUrag is offline
Old 06-10-2005, 05:09 PM   #17 (permalink)
here get the zipped archive.
