| Forum |
#1 (permalink) |
when i click on in it the kpackage comes i then click on install another window comes now in the left side ther is wine and an insall button when i click on install button it asks me for the ROOT login passowrd now what is the password ? i am using knoppix live help me |
#2 (permalink) |
The default root password is 12345 or 123456 for installing a software u must go for root only.And rpm package is like setup file in windows just double click in it .It will install.
Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader.I am not responsible for what you do with it. |
#3 (permalink) | ||
Using FAQ
Sometime you'll think you understand everything ...Then you'll regain consciousness |
#5 (permalink) |
ok now the password problem solved but a new problem arrised
"</wine/wine-20030618-1rh8winehq.i686.rpm';echo RESULT=$? error: cannot open Packages index using db3 - No such file or directory (2) error: cannot open Packages database in /var/lib/rpm RESULT=1" this hapens with every rpm package help me to install it |
#6 (permalink) |
well, i didnt tried installing softwares on knoppix yet. (i use it ver rarely). knoppix is a debian based machine. so deb packages will do. try converting rpm to deb using alien.
http://freshmeat.net/projects/alien/
#7 (permalink) |
Location: If I had a webcam u could have seen me, before your eyes.
well doesn't knoppix live come with a already working wine?....
also plz help me install it with suse..
Searching for dell studio 15 ?? dell studio 15 review @ my blog vandit007.blogspot.com And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !! |
#8 (permalink) |
Knoppix has no root password and wine comes by default with knoppix.Just rightclick the .exe file and click open with and type wine.It should work.If not configure wine just running the command wine (Alt+F2)
| Bookmarks |
| Thread Tools | |
| Display Modes | |
