Do you want to search within the filename, or search the contents of the files as well?
If the former, you can simply use the "locate <filename>" command, it will search a compact database of the files, and not the filesystem itself, and hence will be very fast. Use "updatedb" as root to update the database manually.
For searching within files, I am sorry, but as far as I know, there is no quick way to do that, as linux uses a lot of ASCII text files (shell scripts, configuration files). But there was a desktop search thingy for Gnome, I forget its name right now.
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
