Old 12-09-2005, 03:30 PM   #1 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Enabling Num Lock
How do u enable auto num lock on in FC4 ?
I mean its not a problem to hit the key but as in windows i dont get it on as default...
how to ?
Harsh J
www.harshj.com
QwertyManiac is offline
Old 12-09-2005, 04:58 PM   #2 (permalink)
desertwind's Avatar
Add the following code in /etc/rc.d/rc.local
echo "Activating Numlock ..."
for i in 1 2 3 4 5 6; do
/usr/bin/setleds +num < /dev/tty${i} > /dev/null
done
or for anm detailed explanation, go here
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
Old 12-09-2005, 07:21 PM   #3 (permalink)
Commander in Chief
thnx a lot desertwind - problem solved !
I did this :
KDE > Control Center > Peripherals > Keyboard > NumLock > Turn On.
Thnx a lot for that link !
Harsh J
www.harshj.com
Old 21-09-2005, 04:58 AM   #4 (permalink)
desertwind's Avatar
This tool also do it.
http://download.fedora.redhat.com/pu...4.fc4.i386.rpm
