Old 11-09-2005, 10:14 PM   #1 (permalink)
Default How to auto turn off monitor?
In windows we can give the time say auto turnoff monitor after 1 minute.These feature avaliable in red hat 9.0??If so how to use??help me.
rajas700 is offline
Old 11-09-2005, 11:45 PM   #2 (permalink)
vignesh's Avatar
go to your xscreensaver and check the make aware of power management
vignesh is offline
Old 12-09-2005, 12:44 AM   #3 (permalink)
String Phreak
mediator's Avatar
go to command as root and type "shutdown -h -t 10"
Thiswill shutdown ur PC after 10 seconds!
mediator is offline
Old 12-09-2005, 06:56 AM   #4 (permalink)
Netjunkie's Avatar
He dosent want to shut down his computer, he only wants to turn off the monitor.
Please read the entire question.
Netjunkie is offline
Old 12-09-2005, 02:43 PM   #5 (permalink)
String Phreak
mediator's Avatar
Huh, can U turn off power of PC speakers from any software or can u turn off printer from software provided by it?? Talk mature!
U cant turn off monitor power except manually by hand by pressing its button or by switching Off main power GET IT?
mediator is offline
Old 12-09-2005, 06:15 PM   #6 (permalink)
Netjunkie's Avatar
Dear Mr.mediator
You can definetly turn off your monitor after some specified amount of time.
In windows you can very well do this from the power options.
This guy wants to do it in LINUX.
GET IT?
I have posted a screen shot please see this
Talk mature!!
Old 12-09-2005, 07:03 PM   #7 (permalink)
desertwind's Avatar
may be this will help
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
Old 12-09-2005, 07:51 PM   #8 (permalink)
String Phreak
mediator's Avatar
Ok, Thanx!
mediator is offline
