Old 10-09-2005, 12:44 AM   #1 (permalink)
Default Kubuntu Internet LAN configuration Help
Well i had this problem with my Suse 9.1 well i think i have this problem with all linux that run on KDE coz when i was using ubuntu the net worked properly but with suse 9.1 and Kubuntu 5.04 same problem
well let me get down to the problem
how do i enter all these settings, these are my net settings:-
ip address is 10.0.0.203
subnet mask 255.255.255.0
GateWay 10.0.0.1
Preferred DNS 10.0.0.1
well i was able to enter the first three seetings but when it comes to Preferred DNS i cant fin the option and when i tried it some place where it had to do some thing with the DNS and i entered the DNS ip it says enter a "Alias" first what should i do Plz help me Slove my problem then i can jump totally from Windows to Linux
fighting for peace is like ****ing for virginity
cryptid is offline
Old 10-09-2005, 07:23 AM   #2 (permalink)
Just open the file /etc/resolv.conf, and add this line there -
nameserver 10.0.0.1
If it still doesn't work, type "ifconfig" in a console prompt and post the output here.
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
ujjwal is offline
Old 10-09-2005, 01:23 PM   #3 (permalink)
K thanx i will try it now and if i have any problems i will ask u again
cryptid is offline
