Old 07-09-2005, 08:49 PM   #1 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Eclipse problem in FC4
The Eclipse platform for java crashes always when i start it.
i mean that it loads perfectly but after the main page is displayed it crashes and i m unable to even shutdown my pc.
i tried it both on Gnome and Kde but it crasshed on both.
whats the problem ?
Harsh J
www.harshj.com
QwertyManiac is offline
Old 07-09-2005, 11:06 PM   #2 (permalink)
desertwind's Avatar
Are you using root account ?
Try invoking Eclipse from a normal user account
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
Old 08-09-2005, 06:22 PM   #3 (permalink)
Commander in Chief
Tried both yet it crashes .
Harsh J
www.harshj.com
Old 11-09-2005, 07:38 PM   #4 (permalink)
Commander in Chief
Any more ideas plz ?
Harsh J
www.harshj.com
Old 11-09-2005, 08:16 PM   #5 (permalink)
Satissh S's Avatar
@querty: I had the exactly same problem as ur facing. I did know to do anything but to install fc3 and install fc4 with eclipse over it. It worked.
I guess this is the only way to solve probs in linux for newbies like me!!!
Call it Emacs,
Love it or Leave it.
Satissh S is offline
Old 14-09-2005, 07:39 PM   #6 (permalink)
tech_cheetah's Avatar
I had the same problem and the problem was solved.
Actually eclipse takes a huge amount of memory while loading.
So if u don't have large ram(512MB) or swap space then u will face problem.So u can solve the problem by incorporating swap file or swap partition or by increasing ram.
Be honest . By that way u can be sure that the world is short of atleast one rascal.
tech_cheetah is offline
Old 14-09-2005, 09:59 PM   #7 (permalink)
desertwind's Avatar
i do have 1 gb ram, but still it crshes if i'm invoking it from root. i got no problems if its a non-root account
Old 22-09-2005, 01:23 PM   #8 (permalink)
Commander in Chief
i have 512 mb,
K problem solved now, i reinstalled Eclipse and ran as user now too...
It ran now,
thnx for ur replies !
Hats off to you guys !
Harsh J
www.harshj.com
