Old 01-09-2005, 11:33 PM   #1 (permalink)
Default not able to hear sound in linux! :(
hi,
i have 865 chipset, 2.4 ghz intel processor, 512 DDR. i installed mandriva linux. it detects and has installed an audio driver for intel 865, AC97 audio driver. but i am not able to hear any sound when playing music. i hav creative 5.1... cud any1 help on this thku.
/legolas
legolas is offline
Old 02-09-2005, 09:01 AM   #2 (permalink)
Make sure that the sound volume levels are unmuted. Run the following in a console
amixer set PCM 100 unmute
Also, verify that the correct drivers have been loaded, run
lsmod | grep snd
and post the output here
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
ujjwal is offline
Old 05-09-2005, 09:55 AM   #3 (permalink)
String Phreak
mediator's Avatar
What r u playing r music filez in ...... XMMS?
Yeah in most of the distros Ifound volume level is either muted or at very low! Unmute it and raise the volume level.
If filez dont play in XMMS then u have to copy the Mp3 plugin, anyway try realplayer or mplayer for playing filez too.
mediator is offline
Old 05-09-2005, 06:51 PM   #4 (permalink)
vignesh's Avatar
Try systen\m settings ->soundcard detection
vignesh is offline
