Old 26-08-2005, 08:26 PM   #1 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default How to install Fedora Core 4 using ISO images?
Guys!
I tried to extract the ISO images of FC4 (from Digit DVD) using ISO Buster, but found that there was no Dosutils directory!
I wanted to install FC4 using ISO images without burning CD, like as we can install Red Hat linux using its Images.
I also tried to boot from Autoboot command of Dosutils directory of Red Hat 9's Image, but no benefit...
Is there ne way to install FC4 using its ISO images without burning the CD?
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 26-08-2005, 10:46 PM   #2 (permalink)
Default Try it
First make a boot disk by extracting boot file(msi) from the cd .And then boot the computer with the disk and then select F2 for options.u will find several commands in that u select a option to install from Hard disk(Before u do this copy all the image file into one harddrive)Then it will search for the file and starts working(Installation).
rajas700 is offline
Old 26-08-2005, 11:04 PM   #3 (permalink)
and it is very case sensitive.. so be clear of the folder name.. Linux and linux is diff..
or just burn the CD1 .. put the rest in a FAT32 drive folder and while installing put linux askmethod.. it will then ask for which method and then choose Hard disk.. and then give the path.. rest is simple..
I\'M BACK
khandu is offline
Old 26-08-2005, 11:08 PM   #4 (permalink)
desertwind's Avatar
There is no dosutils in FC4, since the boot image cant be fit into a floppy anymore. there is an file named boot.iso in the images directory, which can be burned to a cd and can be used for hard disk install. The diskboot.img file for can be written to a USB pendrive or other bootable media larger than a floppy.
And, posting such threads in Open Source will fetch more replies.
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
Old 26-08-2005, 11:37 PM   #5 (permalink)
Microsoft MVP
I don't hv writer or pen drive!
Thats why I was trying to install FC4 using HDD.
But as u guys mentioned that I'll need either a pen drive or writer for it.
It can't be installed using floppy.
So sad...
Old 27-08-2005, 06:28 AM   #6 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
Please check out this and see if it helps you. I think it should do the trick. I used the earlier method said above which involves writing the first disk and then just use the askmethod parameter. But since you dont have a writer I think this should do fine.
Several Floppy Install
FilledVoid is offline
Old 27-08-2005, 01:00 PM   #7 (permalink)
Please go through this thread -
http://www.thinkdigit.com/forum/view...=225409#225409
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
ujjwal is offline
Old 27-08-2005, 01:33 PM   #8 (permalink)
Microsoft MVP
thnx for the links..
I'll apply the method and will tell u whether it works or not!!!
Old 27-08-2005, 06:43 PM   #9 (permalink)
Commander in Chief
QwertyManiac's Avatar
Does Loadlin support NTFS drives for reading images ?
Harsh J
www.harshj.com
QwertyManiac is offline
Old 27-08-2005, 07:34 PM   #10 (permalink)
Microsoft MVP
thnx ujjwal.
Ur trick worked like a charm!
Very easy method and 100% working.
thnx...
Old 27-08-2005, 08:41 PM   #11 (permalink)
Qwerty, you can try using a tool called NtfsDos for accessing the NTFS partition from a DOS bootable floppy. Loadlin will run well from a DOS floppy (which can be a win9x bootdisk). I, however, have not tried this, so I am not sure if it will work.
Vishal, good to hear it worked
ujjwal is offline
Old 01-09-2005, 01:26 PM   #12 (permalink)
Commander in Chief
Thnx Ujjwal, it works !
Harsh J
www.harshj.com
Old 01-09-2005, 07:45 PM   #13 (permalink)
vignesh's Avatar
Can suse and Mandrake be installed from the hardisk.I know mandrake can be done but how same as redhat.
vignesh is offline
Old 01-09-2005, 08:06 PM   #14 (permalink)
Virtually any linux distro can be installed from its ISO image, but some are more difficult than others. Loadlin is a nice tool for this purpose. All you need to do is copy the kernel image and init ramdisk to the hard drive, and use loadlin with the suitable parameters. From within the installation, you will need to select the source of the installation media. If no option for this exists, you will have to get a console (CTRL+ALT+F2), mount your hard drive, mount the ISO image at the position where the CD drive is mounted, and run the installer. Some other esoteric installers may need some extra tweaks ...
ujjwal is offline
