Old 23-08-2005, 03:37 PM   #1 (permalink)
Default Problem with Ubuntu (Live & Installed Both)
It's the ame problem with both. While booting up, it hangs on :-
Starting Hotplug Subsystem
This never happened on my other system, any ideas why ?
cyberia.in is offline
Old 23-08-2005, 05:25 PM   #2 (permalink)
Hot plug is the hardware detection tool used by linux distro's, especially live cds. Seems one or more of your hardware is causing the tool to hang for a very long time. Instead of booting by pressing enter at the prompt, boot by entering linux nohotplug and see (sometimes it might be "ubuntu nohotplug" or something, check the help screen, usually accessed by F1, to get more info).
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
ujjwal is offline
Old 24-08-2005, 08:09 PM   #3 (permalink)
Satissh S's Avatar
Default Re: Problem with Ubuntu (Live & Installed Both)
Hey U hav Nvidia Gfx card don't U. It happened to me when i used my Nvidia geforce fx5200 but doesn't when i don't. Don't know the reason anyways
Call it Emacs,
Love it or Leave it.
Satissh S is offline
Old 25-08-2005, 07:01 PM   #4 (permalink)
vignesh's Avatar
If you have an nvidia card give the command as xmodule=nv while booting with the live cd.
vignesh is offline
Old 26-08-2005, 08:41 PM   #5 (permalink)
Satissh S's Avatar
@ Vignesh : Thanks, It workd. Now i'm using a triple boot
XP , Xandros , Ubuntu
Call it Emacs,
Old 27-08-2005, 02:50 PM   #6 (permalink)
vignesh's Avatar
Have you installed ubuntu ?
vignesh is offline
Old 27-08-2005, 05:34 PM   #7 (permalink)
Satissh S's Avatar
Yes i hav. It paused for a moment in Loading hotplug Subsystem or smthing lik that, Then it cam as failed and it booted into X server.
Call it Emacs,
Old 27-08-2005, 09:06 PM   #8 (permalink)
vignesh's Avatar
ok fine...
vignesh is offline
Old 08-09-2005, 11:34 PM   #9 (permalink)
Well i had the same problem during Suse 9.3 installation but ubuntu works great for me
fighting for peace is like ****ing for virginity
cryptid is offline
