Old 30-07-2011, 01:34 PM   #1 (permalink)
ss max's Avatar
Arrow Problem installing Ubuntu
I was using ubuntu 10.04 LTS along with Windows from long time but some days before i thought to upgrade it and using the update facility i did so but after full update some problem occured and so ubuntu was not able to boot correctly then i tried to reinstall it after removing the previous installation but then after completing every step when it was installing in half way the screen started blinking and remained so for a long time then i cancelled the installation and from since then i am not able to install ubuntu on my desktop i tried downloading the new image (ubuntu 11.04) from the site and burned it same problem was coming again and again in installation . I am not able to figure out the problem , please suggest a remedy .
ss max is offline   Reply With Quote
Old 30-07-2011, 06:04 PM   #2 (permalink)
change is constant!!
khmadhu's Avatar
Default Re: All Ubuntu problem Here .
did u tried formatting the partitioning to ext4 in which u want to install Ubuntu.?
if problem persists try scanning whole drive for errors/bad sectors and fix it. and then try to install again..
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
khmadhu is offline   Reply With Quote
Old 30-07-2011, 06:28 PM   #3 (permalink)
Mozilla Rep
sygeek's Avatar
Please be brief here.
sygeek is online now   Reply With Quote
Old 31-07-2011, 01:53 PM   #4 (permalink)
ss max's Avatar
Default Re: Problem installing Ubuntu
I have done the formatting in that format only and also i have checked for errors but everything is fine.
Old 01-08-2011, 11:38 AM   #5 (permalink)
khmadhu's Avatar
r u trying to install ubuntu from windows using Wubi..? OR u r installing from boot..?
try to install from USB drive. by using pendrivelinux or unetbootin software..
Old 06-08-2011, 11:52 AM   #6 (permalink)
ss max's Avatar
I Have tried that way of using the pendrivelinux but even after changing my boot order i am not able to boot from pendrive .
Old 12-08-2011, 10:15 PM   #7 (permalink)
Anish's Avatar
Try this way:
1. Boot up with the livecd
2. run gparted and partion your hdd for linux - mint has gparted in livecd i dont know about ubuntu. (4 partitions is enough /[ext4], /home[ext4], /boot[ext4], swap)
3. Then reboot and try installing from the live cd itself.
The secret ingredient is nothing
Anish is offline   Reply With Quote
