Old 22-07-2011, 03:38 PM   #1 (permalink)
Default Problem installing VMware workstation on Ubuntu 11.04
I downloaded and installed successfully vmware workstation 7 on my computer.
but now when I run it it ask for kernal headers of linux kernal 2.6.38-10-generic , some C files it is looking for to compile its modules. I have searched the internet for the location of the files but I have not been able to. Can any one please tell me where are these linux headers stored in Ubuntu 11.04
Asmeet is offline   Reply With Quote
Old 22-07-2011, 06:07 PM   #2 (permalink)
change is constant!!
khmadhu's Avatar
Default Re: Problem installing VMware workstation on Ubuntu 11.04
/usr/src/linux-headers-2.6.38-10-generic
if u want to search any file quickly.. use locate command
first enter below command
sudo updatedb
and then give below command
sudo locate filename
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
khmadhu is offline   Reply With Quote
