Old 18-06-2011, 08:53 AM   #1 (permalink)
bijay_ps's Avatar
Angry [SOLVED] unable to lock administrator directory problem
I was trying to install gcc by using "sudo apt-get install gcc",using terminal window ofcourse,and i gave me an error msg that
E: could not get lock /var/lib/dpkg/lock - open(11: Resource temporarily unavailable)
E: Unable to lock the administration directory(/var/lib/dpkg/),is another process using it?
I have installed Ubuntu 11.04 inside windows 7 in E drive.
even I tried "sudo bash" command and after that to install gcc..... but again the same problem... so please help me
Follow 7H3 G33K !nside YOU
bijay_ps is offline
Old 18-06-2011, 09:51 AM   #2 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Default Re: unable to lock administrator directory problem
Well, just reboot the machine, and it'll get solved.
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is offline
Old 23-06-2011, 11:07 PM   #3 (permalink)
Ballack Junior
tuxybuzz's Avatar
the error you are indicating usually means that another resource/process has currently acquired the lock ( i.e it is making some changes of its own..the usual culprit in my cases is the automatic update).
So rebooting should solve it or alternatively you could wait till the lock is freed.
tuxybuzz is offline
Old 25-06-2011, 08:40 PM   #4 (permalink)
bijay_ps's Avatar
well it worked...... thanks U guys
bijay_ps is offline
