Old 08-06-2011, 07:56 PM   #1 (permalink)
bubusam13's Avatar
Default [SOLVED] Ubuntu package installation help
help help help..... i m new to Ubuntu and this has become a headache.
! month ago I installed ubuntu 10.10. Then I downloaded many .deb packages and saved those in my hard disk for future use. Due to some circumstances I have to uninstall ubuntu later.
Now after 3 months I again Installed ubuntu 10.10.
I have gone to system> administration>synaptic package manager > File (menu) > add downloaded packages.
I selected all the packages I have previously saved in my hard disk. I had my Internet disconnected then. After selecting when I apply changes, installation fails.
I now connected my Internet and clicked apply changes. Now synaptic in again downloading the packages from the Internet. But I have already those packages stored in my hard disk.
Even when I double click a deb life, installation fail.
PS: last time i found on internet a guy suggested some changes in "software sources". I forgot what changes but it worked then
The first step to getting the things you want out of life is this: Decide what you want.
bubusam13 is offline
Old 08-06-2011, 08:08 PM   #2 (permalink)
Sami Hyypiä, LFC legend
Liverpool_fan's Avatar
Default Re: Ubuntu package installation help
Is your APT been interrupted? In that case apt-get -f will fix the problem.
If the PC is connected, post the output of any apt-get to debug.
sudo apt-get install screen
Post the output. Make sure you enclose them in [CODE][/CODE] tags.
For offline installation of packages, check out http://askubuntu.com/questions/974/h...ftware-offline
Experience true education in Computer Science - http://www.udacity.com | http://www.coursera.org
Read before asking / messaging any moderator for any query: FAQ + answers for new members
Don't use forum for chatting. Visit http://webchat.freenode.net/?channels=krow, enter nick and connect.
Liverpool_fan is offline
Old 08-06-2011, 09:46 PM   #3 (permalink)
utkarsh009's Avatar
these steps may help :
1. try sudo apt-get update.
2. next time backup everything in /var/cache/apt. for now you can add those repositories (if other than default) from which you downloaded.
3. it may have unmet dependencies. so you may wanna try downloading the tarball.
dell p2211h | amd athlon II X4 635 @2.9 GHz. |gigabyte GA-880GM-UD2H |corsair 2x2GB DDR3 1333 MHz. RAM | Seagate 500 GB HDD |tagan tg500-u37|LG Optimus One P500
utkarsh009 is offline
Old 08-06-2011, 10:15 PM   #4 (permalink)
One of the problems, will be that you may have dependencies, which can only be downloaded from internet through repositories or you may have dependencies which are not present in repositories, post the error message.
abhijangda is offline
Old 09-06-2011, 02:00 AM   #5 (permalink)
bubusam13's Avatar
@all... this is what I have done.... I have backup-ed the complete apt folder. This is the reason I cant understand why installation fails.
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
This is what i m getting
Old 09-06-2011, 08:04 AM   #6 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Well, restart your OS.
Alternatively you can do a ps -e and kill the process.
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is offline
Old 09-06-2011, 08:28 AM   #7 (permalink)
utkarsh009's Avatar
+1 restart your os
Old 09-06-2011, 11:51 AM   #8 (permalink)
bubusam13's Avatar
I just solve it.
On terminal I typed
sudo apt-get update
Took some seconds to update and solved... don't know whats actually happened but it solved
Old 09-06-2011, 12:19 PM   #9 (permalink)
utkarsh009's Avatar
@op: yup i already told you that. maybe you didn't pay attention to my words. anyways i am glad i was able to help.
Old 09-06-2011, 12:35 PM   #10 (permalink)
bubusam13's Avatar
I paied much attention to your second line. I reloaded info in synaptic package manager. I thaught it will do? anyway, can u tell me what this actually does, apt-get update. what apt-get is ?
Old 09-06-2011, 12:38 PM   #11 (permalink)
Simply a DIGITian
aptitude is the package manager, apt-get is same.
apt-get update updates the repository and fetch if any update is available on installed apps.
Old 09-06-2011, 12:42 PM   #12 (permalink)
bubusam13's Avatar
Thanku
Old 09-06-2011, 12:52 PM   #13 (permalink)
Simply a DIGITian
No sorry, apt-get update just updates the repository, apt-get upgrade does the update
Silly mistake.
Old 09-06-2011, 02:27 PM   #14 (permalink)
Mozilla Rep
sygeek's Avatar
Happens when a process is using apt-get in the background. In your case, it was the synaptic package manager, but it failed.
Either you can kill the process PID, the synaptic package manager in this case.
OR
Use this command:
sudo rm /var/lib/dpkg/lock
To install a deb package use this command in the terminal:
sudo dpkg -a ~/package/path
sygeek is online now
Old 09-06-2011, 04:13 PM   #15 (permalink)
bubusam13's Avatar
Thanku all for sharing your knowledge. i'm bookmarking this page
Old 09-06-2011, 04:15 PM   #16 (permalink)
Simply a DIGITian
Ok, closing and marking it as [SOLVED]
