Old 05-06-2011, 03:52 PM   #1 (permalink)
Exclamation Problem in redhat linux
hai friends,
how to disable mass storage like pen drive usage in redhat linux or opensolaris? and is there is any way to check that mass storage device has been used in the computer like windows have.
thanks in advance
sudiphans is offline   Reply With Quote
Old 05-06-2011, 04:59 PM   #2 (permalink)
Default Re: Problem in redhat linux
Have a look at this link, see if it helps you
Link, Click here -> Linux Disable USB Devices (Disable loading of USB Storage Driver)
Old 23-06-2011, 11:04 PM   #3 (permalink)
Ballack Junior
tuxybuzz's Avatar
like in the above link adding "nousb" to kernel booting options works. But I suppose he wants to disable only Mass Storage Devices and not USB in general so the first method pretty much does it.
tuxybuzz is offline   Reply With Quote
