Old 17-05-2011, 06:49 AM   #1 (permalink)
Default Ubuntu 9.04 Raid 0 Problem [Not Detecting Raid 0 Drive]
When i tried Ubuntu 9.04 Live DVD it was not detecting my Raid 0 Drive [500GB] , detecting only my Back up hard disk [Sata ]
I cant find Raid driver from GIgabyte Website
so , is there any way to config my Raid 0 on Ubuntu 9.04 or latest ? (i do have latest Ver(not sure if it is LIVE CD image or normal CD img ) but need to burn it (have as .ISO image on my bkup harddisk )
Config on my Sign
will b using Ubuntu X64 bit
Thank you
AMD Phenom II X6 1055T ,Benq G2220HD 22 ,GIGABYTE GA-880GM-UD2H ,COOLER MASTER Elite 310 ,CORSAIR 2GB 240-Pin DDR3 X3[6GB] , FSP Saga II 500 W HD 5750 . Hyper 212+ OS :Win 7 64 bit
Rajesh345 is offline   Reply With Quote
Old 17-05-2011, 11:25 AM   #2 (permalink)
Default Re: Ubuntu 9.04 Raid 0 Problem [Not Detecting Raid 0 Drive]
This link should help you a little-
[ubuntu] BIOS Raid 0 Not Detected on Install - Ubuntu Forums
Old 17-05-2011, 07:56 PM   #3 (permalink)
Mozilla Rep
sygeek's Avatar
Do you already have Windows installed, i.e. are you trying to dual boot?
sygeek is offline   Reply With Quote
Old 17-05-2011, 08:39 PM   #4 (permalink)
Originally Posted by thetechfreak View Post
Thank u for link , After some searching Ubuntu forum i heard i cant install Ubuntu on FakeRaid (the one which require Bios to config raid )
on mY Gigabyte M.B i am using Bios to config so i guess i am outof luck
Yes Win7 installled on my Raid 0Array [100GB Partition (500GB raid 0 drive) ]
2nd H.D Sata 500GB =For Back UP ONLY
Old 17-05-2011, 08:54 PM   #5 (permalink)
Mozilla Rep
sygeek's Avatar
Then you can install Ubuntu with wubi, I guess that's the only option you have.
Old 17-05-2011, 09:09 PM   #6 (permalink)
i will try now and post result
Thank u
Old 17-05-2011, 10:03 PM   #7 (permalink)
No prob man. Happy it helped.
Yeah, wubi installation is best for you.
Old 17-05-2011, 11:04 PM   #8 (permalink)
Tried wubi now
From wubi installed choosed a 80GB Raid partition after reboot getting error unable to find installer media
i will stick with windows only -_-
Old 17-05-2011, 11:43 PM   #9 (permalink)
Mozilla Rep
sygeek's Avatar
^try using it in a Virtually.
