Old 25-04-2011, 09:58 PM   #1 (permalink)
Anand_Tux's Avatar
Default How to install OpenSuse 11.4 KDE iso through USB
I have downloaded the OpenSuse 11.4 iso from the OpenSuse website the problem is that my DVD drive is not working. I have tried the suse image writer from windows but the pen drive hangs after the boot,please suggest me a way out how to install it from the pen drive??
Artificial Intelligence is no match for Natural Stupidity.
Anand_Tux is offline   Reply With Quote
Old 25-04-2011, 11:46 PM   #2 (permalink)
Electronic.
Neuron's Avatar
Default Re: How to install OpenSuse 11.4 KDE iso through USB
First make sure that your motherboard supports booting from usb.
If it does then download Yumi
Plug in your pendrive.Format it in FAT filesystem.
Run the application goto the 'drive selection and distro options' page.
Select the pendrive from the dropbox.Then select 'try an unlisted iso' from the list and browse to and select your opensuse image and click create.
Never tried it myself but i think it will work.
I don't always make sense,but when I do,I don't.
Neuron is offline   Reply With Quote
Old 26-04-2011, 02:10 PM   #3 (permalink)
Anand_Tux's Avatar
I tried yumi but it hangs when I select Live KDE or Installation from the menu, please help??
Old 26-04-2011, 05:09 PM   #4 (permalink)
BIOS Terminator
nims11's Avatar
seems like your pen drive is faulty or the installation is corrupted.
yumi should have done the job.
nyways, try UNetbootin - Homepage and Downloads
nims11 is offline   Reply With Quote
Old 26-04-2011, 08:25 PM   #5 (permalink)
Electronic.
Neuron's Avatar
If nothing else works you can use Virtualbox and install Opensuse within windows.
Old 27-04-2011, 08:53 AM   #6 (permalink)
Anand_Tux's Avatar
There is nothing wrong with my pen drive. I have installed Ubuntu 10.10 & Linux Mint 10 from my pen drive, it's just that OpenSuse is giving me headache, and also I have tried unetbootin but it just hangs when I select live KDE or Installation.
