Old 08-08-2005, 11:34 AM   #1 (permalink)
vignesh's Avatar
Default Urgent help needed
I installed a new graphical greeter which was corrupted.When I boot into Fedora core 3 I get a message "the graphical greeter you installed is corrupt" and an ok button.how do I restore the graphical login screen to the default one ?
vignesh is offline
Old 08-08-2005, 12:09 PM   #2 (permalink)
Editing /etc/inittab and changing default run level to (gui mode) as 5 instead of 3(command mode) should help. There are totally 6 run levels, i know four outta them. Iam not sure though
runlevel 1 ===> Single user mode
runlevel 3 ===> text mode
runlevel 5 ===> GUI mode
runlevel 6 ===> restart.
runlevel 4 and 2 are unknown to me.
experts pls have a say.
Hibernating ....
banned2wise is offline
Old 08-08-2005, 01:36 PM   #3 (permalink)
FooBar Guy
GNUrag's Avatar
run gdmsetup from the console. You'll get and option to change gdm greeter theme.
If you are not able to even start GDM then login as root from the console and edit /etc/gdm/gdm.conf
Then remove or comment these lines.
GraphicalTheme=gdm-tobacco_sky-nld-slack
GraphicalThemeDir=/usr/share/gdm/themes/
http://web.gnuer.org
GNUrag is offline
Old 08-08-2005, 05:19 PM   #4 (permalink)
vignesh's Avatar
I did another way actually
pressed a while grub was booting and typed 3 so it booted into runlevel mode3 that is text mode ,logged in and typed startx and then changed the greeter.
vignesh is offline
Old 08-08-2005, 05:22 PM   #5 (permalink)
vignesh's Avatar
How do I change the bootscreen(bootsplash screens).I downloaded 2 but the installation is only given for suse not fedora core 3.
To install:
1 extract to /etc/bootsplash/themes/
example: /etc/bootsplash/themes/susegreensplash
2 use Yast bootsplash theme changer-by mouseclicks: Yast>system>/etc/sysconfig Editor>system>boot>theme>type name of theme (susegreensplash)>finish
3 as superuser (root) type in terminal: mkinitrd -s 1024x768
... done ... reboot, and you will see the new bootsplash.
vignesh is offline
Old 08-08-2005, 10:20 PM   #6 (permalink)
sba
How comfortable are you with compiling a new kernel? Also what Graphics Card do you have? If you have a decent card (>64MB) and know how to compile your own kernel then you can have a look at http://www.bootsplash.org/
I have never been able to get bootsplash working (thats another place where my luck never favours me). It might work for you so try it out
sba is offline
Old 09-08-2005, 08:09 AM   #7 (permalink)
vignesh's Avatar
I will try and let you know.
vignesh is offline
