Results 1 to 4 of 4
06-08-2005, 10:29 PM #1Broken In
- Join Date
- May 2005
- Location
- Bangalore
- Posts
- 102
" GRUB file not read properly " Error
Hi,
First some background....
I installed RH 8.0 in my old system without a glitch during installation(text only no GUI)....
Before this I was using Vector Linux 4.3 with LILO as bootloader.
Now even after installing GRUB LILO refused to go away.
So i used fdisk /mbr using a floppy disk.
Now i tried installing GRUB from rescue mode by the usual chroot /mnt/sysimage etc (as explained in the sticky thread)
But it said some permission error and stuff.
So ,I booted from a boot disk and under root and gave the following command....Code:grub-install /dev/hda
It gave /boot/grub/stage1 not read properly.
I even checked grub.conf file .
Details are k there.
So please help me solve this.
Thanks for reading such a looong post
\"Cogito,Ergo Sum\"
06-08-2005, 10:41 PM #2Alpha Geek
- Join Date
- Dec 2003
- Posts
- 780
Did you ensure to chroot to your linux partition before running grub-install?
The GRUB installer will look for the files it needs under /boot/grub, and store their physical address in the actual bootloader. If the installer does not find the required files, you will get the error message.
I assume that
/dev/hda1 - Redhat /boot partition (if present)
/dev/hda2 - Redhat / partition
1. Boot into your boot disk and mount the / partition (mount /dev/hda2 /mnt/lin)
2. chroot to this directory (chroot /mnt/lin), mount the /boot partition at the appropriate place (mount /dev/hda1 /boot)
3. Now run grub-installHardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
06-08-2005, 11:26 PM #3Broken In
- Join Date
- May 2005
- Location
- Bangalore
- Posts
- 102
/dev/hda1 is my / partition...no seperate partition for /boot
Cud u please elaborate what u meant by "Mount /boot at appropriate place"??
Thanks in advance...\"Cogito,Ergo Sum\"
07-08-2005, 07:41 AM #4Alpha Geek
- Join Date
- Dec 2003
- Posts
- 780
If you don't have a seperate /boot partition, you can leave that part. I mentioned it as I thought redhat creates a seperate /boot partition by default.
Need urgent help with """"initialising and establishing link" error
By chinmaya in forum Hardware Q&AReplies: 2Last Post: 23-07-2012, 04:17 PM -
Linux backtrack - "No root file system is defined" error
By Sivakumar in forum Open SourceReplies: 2Last Post: 23-03-2011, 06:06 PM -
Please check this, "Raw read error rate"
By jack_the_ripper in forum QnA (read only)Replies: 6Last Post: 26-11-2008, 10:57 AM -
Pen drive error messg"Unable to open Script file "F:\MSDLL.dll.vbs"
By janitha in forum Software Q&AReplies: 19Last Post: 20-04-2007, 10:25 PM -
Memory could not be "Read" error...
By prasad_den in forum QnA (read only)Replies: 3Last Post: 06-02-2007, 07:05 PM
LinkBack URL
About LinkBacks
