Old 06-08-2005, 02:00 PM   #1 (permalink)
mAYHEM's Avatar
Default FC4 Install Problem
I tried to install FC4 from my hard drive using dosutils,upto disk partitioning the text installation works fine,but after the msg'Reading Package Information' it pops a window showing a bug and asks me to submit the bug at FC page.i am installing the distro on logical partitions..is this the problem.earlier i was able to install fc3 on the same partition from hd.So plz help me
mAYHEM is offline
Old 11-08-2005, 10:24 PM   #2 (permalink)
String Phreak
mediator's Avatar
Probably corrupt file installation! try cd installation
mediator is offline
Old 12-08-2005, 06:11 AM   #3 (permalink)
hcp006sl's Avatar
First check all the CDs and then try to install again. If problem persists, please report for further suggestion. This FC4 contains several bugs.
Orkut members are invited to join:
http://www.orkut.com/Community.aspx?cmm=28705185
hcp006sl is offline
Old 12-08-2005, 08:30 PM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
FC4 has bugs with intel boards a lot...
865 , 915 especially have problems ith boot,
But it is better than the FC3 in quality of Apps...
P.s. Can ny one tell me how ta install M player on FC4 , it gives some compiling error and non support of gcc i think on configuring...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 12-08-2005, 08:47 PM   #5 (permalink)
vignesh's Avatar
Did you remove grub before trying.since FC3 uses selinux.You have to format the partitions and remove grub before installing another distro.
vignesh is offline
Old 21-08-2005, 09:26 PM   #6 (permalink)
Satissh S's Avatar
Hey I don't know about your problem but let me tell u my experience. An error similar to yours occured to me too. When partitioning while u'r creating a new partition u hav to uncheck the tick mark next to the drive where u'r windows Installation is. This got rid off such an error. Or if U give auto partition u hav to do the samething.
Linux Gurus Plz Correct me If iam wrong .
Call it Emacs,
Love it or Leave it.
Satissh S is offline
