Old 05-08-2005, 10:47 PM   #1 (permalink)
mekalodu
iinfi's Avatar
Default EDITED: Linux installation help ....
EDITED: plz scroll down to view my query.... i cud not install FC4
i am gonna install Fedora Core 4 ...
i wanna know if there is a need to install an antivirus and a firewall for Linux ...
and if yes which one ....??
suggest a good freeware antivirus and firewall and antispyware for my Linux ...
thanks ...
mekalodu
iinfi is offline
Old 06-08-2005, 12:19 AM   #2 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
yes , u need to install an antivirus in linux
u may go for Bitdefender Antivirus.
~Phenom~ is offline
Old 06-08-2005, 12:34 AM   #3 (permalink)
sba
If you are not running some kind of mail server or file server for a network then you don't need an Antivirus on your Linux installation. As for firewall you can have a look at Guarddog or Firestarter and you don't need a Antispyware.
sba is offline
Old 06-08-2005, 12:43 AM   #4 (permalink)
mekalodu
iinfi's Avatar
thanks for the info .....
but i m unable to install Fedora Core 4 ... i have previously installed Linux .(like ..SuSe)
i m not an experienced user n use linux very rarely ....
the installation started after giving me lota problems ..
and then i had selected the full installation (on a 9GB partition ....) it said "congratulations Fedora Linux is intalled" even b4 it asked for the remaining 3 CDs ....
on reboot (i removed the FC4 Disk 1)... and windows XP started ..... ....
i will list how i went abt the installation in detail tomorrow as i m feeling sleepy now .... ....
mekalodu
iinfi is offline
Old 06-08-2005, 12:47 PM   #5 (permalink)
tuxfan's Avatar
I suggest, you install PCQ Linux 2005 (it is based on FC3). It comes with a few anti-virus softwares like ClamAV. Firewalls come with all distros. Additionally, their customisation is also good.
If you want PCQL, you can either contact them directly or contact me
BTW, don't forget to get their PCQL SP1. It contains some bug fixes.
In a GNU/Linux distro installed in a desktop, as of now, I don't feel its necessary to have an antivirus. Due to its architecture, viruses can't really create havoc on a Linux machine. But you never know about the future and its always safer to have an anti-virus with heuristic capabilities installed.
If its a server attached to a few Windows machines, you better have one.
tuxfan is offline
Old 07-08-2005, 12:09 AM   #6 (permalink)
mekalodu
iinfi's Avatar
hi tuxfan,
i will take ur advice. but since i have burned 4 CDs for FC4 frm this month digit DVD ... i wanna install FC4 first to c how it is like ...
this is what i did...
i have 2 HDDs one 20GB (where winXP is installed.) and another 40GB where i have files and some programs stored.
i tried to install FC4 in the HDD which contains Windows XP after creating another partition for it.
but after the installation of FC4 started it refused to accept the partition for partition as it was not a primary partition.(i dont know whats primary partition and logical one )
then i quit the installation and thru WinXP installed Partition Magic 8.0 and created a linux partition (10GB) in the 40GB HDD and then started the FC4 installation again !!!
then the installation proceeded and i selected all the options (all features to be installed) .....
i got a message saying that all the 4 disks are required to complete the installation!!! (i had all the four discs and had tested them using FC4's test and got PASS)
the installation continued for sometime and it didnt ask for the remaining 4CDs !!! and then asked me to click a button to REBOOT the PC ....
on REBOOT i found windows XP booting!!!!
i repeated the procedure and found the same thing happening ...... plz help
mekalodu
iinfi is offline
Old 07-08-2005, 12:46 PM   #7 (permalink)
tuxfan's Avatar
It is very likely that the CDs are buggy and have not been burnt completely. There are already a few threads with FC4 problems going on in this forum itself. So it seems that FC4 is problematic.
Additionally, it may have happened that FC4 got installed properly, but GRUB didn't. Just search at this forum. I (and a few others) have posted on how to install GRUB in MBR. You need to boot from the first CD and go to rescue mode to do that.
But I would still suggest that you get PCQL with SP1. They customisation is really good.
As for partitions, a hard disk can have at max 4 primary partitions. Some old partitioning softwares will let you have only one primary partition.
Rest of the space can be occipied by an extended paritions. There can be logical partitions within extended partitions. FC4 can be installed on a logical partition as well.
tuxfan is offline
Old 07-08-2005, 06:09 PM   #8 (permalink)
Commander in Chief
QwertyManiac's Avatar
@tuxfan
Plz hlp me, i try to boot the installatin disk and afer hittin enter i get an error message after the uniform cr-rom revision 3.20 load that the installer couldnt find the mounted image at (8,3) block of the memory, then i get some rubbish bout kernel kill, kernel helper and more bout some thread class , etc..
I tried several times,
It also says me to append a correct root= name in the boot menu..
What to do ?
Harsh J
www.harshj.com
QwertyManiac is offline
Old 08-08-2005, 12:06 AM   #9 (permalink)
mekalodu
iinfi's Avatar
i checked the FC4 CDs with the built-in check utility..... all CDs PASSed the test ....
and another thing ... the installation process didnt ask for the 2nd 3rd and 4th CDs at all .....
mekalodu
iinfi is offline
Old 08-08-2005, 12:44 PM   #10 (permalink)
tuxfan's Avatar
@QwertyManiac: Please start a new thread and more people will be able to help you. Let iinfi solve his problem here.
@ iinfi: It may so happen that Anaconda (Fedora Installer) version is buggy. Try out FC3 or some other distro and see what happens. But if you still want to try FC4, take some other set of CDs and try.
tuxfan is offline
Old 08-08-2005, 03:14 PM   #11 (permalink)
mekalodu
iinfi's Avatar
ok thanks i will try .... 4CDs gone down the drain ...
thanks for your help tuxfan....
mekalodu
iinfi is offline
Old 09-08-2005, 12:43 AM   #12 (permalink)
tuxfan's Avatar
Why don't you PM GNUrag, firewall, ujjwal, etc. with the link of this thread? They have more knowledge than me. May be you can save your CDs
tuxfan is offline
Old 09-08-2005, 01:20 AM   #13 (permalink)
FooBar Guy
GNUrag's Avatar
lol.. i didnt understand anything of qwerty's problem
@tuxfan, i read every thread in this section.
http://web.gnuer.org
GNUrag is offline
Old 09-08-2005, 01:51 AM   #14 (permalink)
sba
Can you tell us exactly which all options/features you selected for installation. If possible do an install once again and note down all the steps you take. I would also recommend trying a text based install once. May be that will work. FC4 installer has lots of bugs (hv a look at bugzilla and you wd know) but a few hit and trials can be made...
sba is offline
Old 09-08-2005, 11:13 AM   #15 (permalink)
mekalodu
iinfi's Avatar
if u read some of my previous posts i have mentioned the steps which i took ..... well i dont remember more in detail ..
i had selected all the options .......
i will try the text based installation and post the results ..
mekalodu
iinfi is offline
Old 09-08-2005, 11:53 AM   #16 (permalink)
tuxfan's Avatar
Linux For You August 2005 issue has an article on titled Multi-boot your system with Dual Hard Disks The issue has come just 10 mins back. Let me read thru it and I will be able to offer you some tips
Do you want me to scan and send it to you?
tuxfan is offline
Old 09-08-2005, 08:05 PM   #17 (permalink)
Commander in Chief
Srry for wrong language usage but ma probs solved by SBA , the problem exists with most 865 mobo users,
The answer is type an invalid comand and then after validity press enter to jus jump to install sbin loader...
Harsh J
www.harshj.com
Old 09-08-2005, 08:39 PM   #18 (permalink)
mekalodu
iinfi's Avatar
@tuxfan: if u can plz scan and send me the article. my mail ID is iinfi1 AT gmail DOT com
thanks
mekalodu
iinfi is offline
Old 10-08-2005, 11:46 AM   #19 (permalink)
tuxfan's Avatar
I will upload it somewhere and send you a download link by PM
tuxfan is offline
