Old 23-12-2010, 12:19 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
It's true Im not confused
confused!!'s Avatar
Default VLC not running in Mint
I am facing some problems in running VLC in Linux Mint 9. It was running fine until I made some some configuration changes(I dont remember which ones). After that it resuses to open. I have since used Package manager to completely remove and then reinstall VLC but to no avail. It still does not run not does it give any error.
Any idea???
After the game is over, the pawn and the king go into the same box
confused!! is offline   Reply With Quote
Old 23-12-2010, 01:31 PM   #2 (permalink)
Default Re: VLC not running in Mint
Remove the vlc folder from home directory and then it should work.
.config/vlc
Faun is offline   Reply With Quote
Old 23-12-2010, 06:32 PM   #3 (permalink)
confused!!'s Avatar
Yeah, its working now....thanks
LinkBack to this Thread: http://www.thinkdigit.com/forum/open-source/135326-vlc-not-running-mint.html
Thread VLC not running in Mint | Digit Forum | BoardReader This thread Refback 13-02-2011 07:19 PM
