Old 15-11-2010, 01:26 AM   #1 (permalink)
elviento's Avatar
Default please help (ubuntu 10.04)
hi everyone..
i installed ubuntu 10.04 and it was working fine when today after installing
graphics drivers (for ati) and restarting the problem began
when i select ubuntu from the boot menu, then blinking cursor comes
at the top left corner and then the screen goes blank...
the disk usage led indicator too shows no activity....and it stops responding
after waiting a long time...when i press the power button then the ubuntu boot screen comes up and the laptop shuts down....
please tell me how to fix it...i dont want to reinstall again as i applied many updates along with installing other multimedia softwares
its important as i saved all my c programs at the desktop
and also tell me if there is any other way of retriving them(the folder in the desktop).
Thanks in advance.
Oh folks...please reply...
elviento is offline   Reply With Quote
Old 15-11-2010, 11:44 AM   #2 (permalink)
change is constant!!
khmadhu's Avatar
Default Re: please help (ubuntu 10.04)
try with recovery mode or single user mode.
and follow these steps..
https://help.ubuntu.com/community/BinaryDriverHowto
https://help.ubuntu.com/community/RadeonDriver
you can try accessing your files in windows by using following software's. dono exactly whether this will support ext4 type.
chrysocome.net - Explore2fs
or
Ext2 File System Driver for Windows | Download Ext2 File System Driver for Windows software for free at SourceForge.net
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
khmadhu is offline   Reply With Quote
Old 19-11-2010, 03:11 PM   #3 (permalink)
Linoob
celldweller1591's Avatar
try this :
press ctrl+alt+f1 and virtual terminal tty1 will show up. login as root and type :
startx or sudo gdm
see if this works for you. And to backup your programs, use ubuntu livecd and cmount the ubuntu home partition and copy the contents to a pd or anywhere u want.
root@Celldweller#ping www.linoob.com
Ubuntu User # 31222
Linux User # 516252
celldweller1591 is offline   Reply With Quote
