Hi,
Most probably the installer is trying to use a higher resolution/refresh rate than supported. I am unfamiliar with the boot options provided by redhat's installer, but try booting with "linux screen=800x600", or maybe you could try 640x480. Also, isn't the "text" installation of redhat 9 menu based? If so, its not much more difficult than the graphical mode, just remember to use <space> to select an option, <TAB> to switch buttons/tabs, <ENTER> to press a button.
And as tuxfan suggested, trying a newer distro is highly recommended. Fedora Core 4, Mandriva 10.1, Suse 9.3, Ubuntu 5.04, PCQLinux 2005 are some good options.
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
