Old 26-07-2005, 01:51 AM   #1 (permalink)
Default Kubuntu GRUB Problem
Hi everzbody
I installed kubuntu and then i have some probs with it,
1.I have a swiss german keyboard but it thinks it is a US american.
2. When i boot my PC it will show grub and then i have to go down and select Windows XP, cant i make a timeout of 8sec. and then it will start windows automatically
Greetz and thx in advance
Vij26
vij26 is offline
Old 27-07-2005, 09:20 PM   #2 (permalink)
Default Re: Kubuntu GRUB Problem
Originally Posted by vij26
Hi everzbody
Vij26
1. Type sudo dpkg-reconfigure xserver-xorg
2. Edit the menu.lst file which u'll find in /boot/grub/menu.lst
For this type sudo kwrite /boot/grub/menu.lst in Konsole Terminal.
You'll find something like this somewhere
title Ubuntu, kernel 2.6.10-5-386
root (hd1,0)
kernel /boot/vmlinuz-2.6.10-5-386 root=/dev/hdb1 ro quiet splash
initrd /boot/initrd.img-2.6.10-5-386
savedefault
boot
title Ubuntu, kernel 2.6.10-5-386 (recovery mode)
root (hd1,0)
kernel /boot/vmlinuz-2.6.10-5-386 root=/dev/hdb1 ro single
savedefault
boot
title Ubuntu, kernel memtest86+
root (hd1,0)
kernel /boot/memtest86+.bin
savedefault
boot
### END DEBIAN AUTOMAGIC KERNELS LIST
# This is a divider, added to separate the menu items below from the Debian
# ones.
title Other operating systems:
root
# This entry automatically added by the Debian installer for a non-linux OS
# on /dev/hda1
title Microsoft Windows XP Professional
root (hd0,0)
savedefault
makeactive
chainloader +1
Edit it so it looks this way:
# on /dev/hda1
root (hd0,0)
savedefault
makeactive
chainloader +1
root (hd1,0)
savedefault
boot
root (hd1,0)
savedefault
boot
root (hd1,0)
savedefault
boot
You can set the timeout seconds here
## timeout sec
# Set a timeout, in SEC seconds, before automatically booting the default entry
# (normally the first entry defined).
timeout 10
Replace 10 with 8 or whatever value u wish
SAVE these settings & restart!
These settings wil make Windows boot by default and will allow u to set the timeout seconds.
By the way, linuxquestions.org is the BEST place for u to post any linux related problems. For issues specific to Kubuntu, go to ubuntuforums.org
Hope this helps
Take care
Yasser
coolblue is offline
Old 28-07-2005, 04:50 PM   #3 (permalink)
Default tHx
dear Yasser
Thank you very much
vij26 is offline
Old 28-07-2005, 06:42 PM   #4 (permalink)
vignesh's Avatar
I got a problem while installing Kubuntu saying kernel package error installing to target partition ?
What do I do
vignesh is offline
Old 29-07-2005, 11:20 PM   #5 (permalink)
You're welcome Vij
Vignesh I'd suggest u retry the installation. BTW did u have Fedora installed before Kubuntu?
coolblue is offline
Old 30-07-2005, 08:08 PM   #6 (permalink)
vignesh's Avatar
Ya Fedora Core 4
vignesh is offline
Old 31-07-2005, 12:23 AM   #7 (permalink)
Originally Posted by vignesh
Ya Fedora Core 4
Thats the problem! Format the whole thing and reinstall Kubuntu...if u want to retain home, format only root partition. Fedora is giving problems probably bcoz of selinux...
coolblue is offline
Old 31-07-2005, 09:26 AM   #8 (permalink)
vignesh's Avatar
But I formated and then only tried.
vignesh is offline
