Old 26-07-2005, 12:58 AM   #1 (permalink)
Default Help Me For Getting Dial-Up Using Mandrake10.1!!
Hi friends
i've Conexant|HSF56K HSFi Modem
but in linux i m not able to dial up using it and i've already checked linmodems.org but i knt get wht i want so pls help me if u kn....
If you want the best, you have to vote for the best
V.I.P.U.L.:= Vigilant Individual Programmed for Ultimate Learning
vipul is offline
Old 26-07-2005, 02:57 AM   #2 (permalink)
sba
The FIRST step towards finding a Linux driver is identifying the modem's CHIPSET. The scanModem tool will help you. Please download and run the scanModem tool.
Go to website again. Download scanmodem tool. Run it and follow the URLs it gives you. You will be able to download the drivers.
sba is offline
Old 26-07-2005, 04:37 PM   #3 (permalink)
You can get the drivers from www.linuxant.com
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
ujjwal is offline
Old 30-07-2005, 02:21 PM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
Try Changing the port (ttsy0,1...) and see in which the modem query responds.
usually com1 (ttsy1).
Harsh J
www.harshj.com
QwertyManiac is offline
Old 21-08-2005, 11:45 PM   #5 (permalink)
String Phreak
mediator's Avatar
1. First query ur modem to see if the system detects it!
2. save the configuration
3. then dial
4. If no ringtone detected, the n give the initialization command ATX1
5. save the configuration
6. now dial
Problem solved!
mediator is offline
Old 22-08-2005, 11:29 PM   #6 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
What I learned from tryign to get an internal modem installed on Mandrake . Itsa pain in the butt, I think the free version does not support the ful speed you can get. Otherwise you have to purchase the other one. I just went and got a new com modem and everything worked fine.
FilledVoid is offline
Old 27-08-2005, 05:15 PM   #7 (permalink)
Commander in Chief
mandrake and xandros alone configured the modem correctly with pre pulse for me...
other all i had to config...
Harsh J
www.harshj.com
