Old 17-07-2010, 08:29 PM   #1 (permalink)
Married!
Rahim's Avatar
Default Help connect Wi-Fi in PCLOS with Belkin Router
I use DELL Studio laptop PCLOS 2010 KDE 4 with a
Broadcom BCM43224 802.11a/b/g/n wifi card.
I have set the router (BELKIN N router) which is connected to BSNL ADSL Modem.
I use "Manage" mode with WPA/WPA2-PSK key and have set DHCP.to both my interface in laptop (eth0 and eth1, eth0 being the wifi)
In the Network Center(PCLOS) I can see the network SSID but when i try to connect, it fails.
However it connects in Win 7 in the same laptop without any problem, when provided with the key.
Since the laptop can see the SSID, it means the wifi card is working fine in PCLOS, right? I have connected my desktop with ethernet and it is assigned ip address of 192.168.2.2 and works fine. So my wifi on laptop should be assigned ip of 192.168.2.3 right? Router can be accessed only from Win 7 at 192.168.2.1
ifconfig shows no ip assigned for eth0 not does iwconfig only MAC address
Help me guys
PCLOS
lspci
04:00.0 Network controller: Broadcom Corporation BCM43224 802.11a/b/g/n (rev 01)
09:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B Pxpress Gigabit Ethernet controller (rev 03)
It seems this chipt wont work testers needed b43-firmware
More bad news
http://wireless.kernel.org/en/users/Drivers/b43
not supported BCM43224 a/b/g/n
This is terrible.
Is there any other distro which support this chip?
|| GNU/Linux User || PCLOS KDE 4.6 || 17" DELL Studio ||
topdocumentaryfilms.com
Rahim is offline   Reply With Quote
Old 18-07-2010, 01:31 AM   #2 (permalink)
Married!
Rahim's Avatar
Default Re: Help connect Wi-Fi in PCLOS with Belkin Router
I solved this by downloading gnome-network-manager-applet and as other like wicd kde networkmanager etc gives me the same "Authentication error", nm-applet just worked!!!
None of the kde-based distros worked
Issue with my new Belkin G Wireless Router a_to_z123 Hardware Q&A 0 26-06-2010 03:41 PM
Need help in setting up Belkin Wifi Router dreamcatcher Chit-Chat 0 24-04-2010 01:21 PM
How To Connect Pc And Laptop With Router ?Plzzz Help sumitkala Hardware Q&A 9 12-04-2010 12:04 PM
Belkin N+ router vs Belkin N+ Blackfire Hardware Q&A 0 21-01-2010 06:53 PM
