Old 13-07-2010, 09:51 PM   #1 (permalink)
vineetrok's Avatar
Default FEDORA 13 Problem
I was trying to install Fedora 13 provided in July DVD on a virtual machine.
But when I tried to open the INSTALL TO HARD DRIVE It didnt open..... please help.
Never buy a car you cant push.
vineetrok is offline   Reply With Quote
Old 13-07-2010, 09:53 PM   #2 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Default Re: FEDORA 13 Problem
What it shows?? I mean when you enter the option blank screen comes and stays or it just stays in the menu or something other??
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is offline   Reply With Quote
Old 13-07-2010, 10:14 PM   #3 (permalink)
vineetrok's Avatar
it shows wait cursor for a while and displays a tab in taskbar saying"starting install to hard drive...." or sumthing and then things come back to normal.....
Old 13-07-2010, 10:33 PM   #4 (permalink)
Simply a DIGITian
What do you mean by things come back to normal??
If things comes back to normal what is the problem??
BTW you stated that you are trying to install in Virtual PC. So what's the configuration of your PC and how much RAM you allocated to Virtual PC.
Asking this coz if you have Dual Core PC then Virtual PC will use only 1 core and most OS'es now will take ages for that and some of them just don't support.
Old 13-07-2010, 10:41 PM   #5 (permalink)
vineetrok's Avatar
by "things come back to normal means" I dont get any installation window jus plain fedora desktop like it was before and no wait cursor.........
hmm.........I'm not using any dual cores
I got a sempron 1.6 ghz
for virtual pc ive allocated 512 mb ram
128mb graphics
etc.........
BTW i've successfully installed Ubuntu 10.04 LTS 32bit and its working perfectly!
Old 13-07-2010, 11:49 PM   #6 (permalink)
Simply a DIGITian
Well...buddy....Here's the fedora minimum requirements : 2.*Requirements
How can I guess anything more if basic stage of minimum requirements is failing.
---------- Post added at 11:49 PM ---------- Previous post was at 11:44 PM ----------
Well...I can only suggest booting fedora with options...I mean when you're trying to boot fedora there are numerous boot options(at the bottom)...you can try with those if that work.
Otherwise....Blank...!!
Old 14-07-2010, 10:47 PM   #7 (permalink)
vineetrok's Avatar
thank you anyways........
I need fedora 13 badly!!!!
I'll try a full install dual booting with my windows xp.
Old 14-07-2010, 11:16 PM   #8 (permalink)
Simply a DIGITian
Hmm....So did the booting with options worked??
Old 16-07-2010, 09:18 PM   #9 (permalink)
vineetrok's Avatar
Finally Installed fedora 12 somehow......
now I want to share its Documents folder with a windows xp machine which is in LAN..any tips on that????
Old 17-07-2010, 10:59 AM   #10 (permalink)
Simply a DIGITian
Sharing Linux and Windows on a LAN need Samba. Check out Fedora's documentation for how to implement Samba.
Old 17-07-2010, 01:24 PM   #11 (permalink)
duh
i havent used any RH product since 2006 so i guess my help wont play any major role. first off? fedora stuffs with too many packages which are really not necessary.
did you try to install fedora with minimal configuration? and or max add the gui i.e. xorg.
and networking? set the networking option in virtual PC i suppose its virtual PC to nat to lan and it can browse the net. why is that you need fedora core 13 only.
sad unlucky 13, we debianphiles are lagging way behind
why not try a livecd.
i downloaded fc 8 live cd and thats all, never turned back at fedora or redhat site for OS but source code for LFS and also the documentation. its the best i have ever seen (afterall they get paid to write good technical paper/documentation).
-paul
duh is offline   Reply With Quote
Old 17-07-2010, 06:43 PM   #12 (permalink)
vignesh's Avatar
Have you install Fedora 12 within a virtual machine ?
vignesh is offline   Reply With Quote
Old 18-07-2010, 04:48 PM   #13 (permalink)
vineetrok's Avatar
@duh yeah even I get a bad feeling about 13!!
anyways.....I've removed fedora 12 now .... its kde and I dont like KDE(dont know why, but i get a bad feel about it!!)finally settled with fedora 11(GNOME)
@vignesh : full install not on virtual pc.
UBUNTU makes things easier with synpatic package manager.
is there any similar tool in fedora.
I'm new to fedora have been using UBUNTU for past 2 yrs!!!!
Old 19-07-2010, 08:37 AM   #14 (permalink)
vignesh's Avatar
You can use yum in fedora and there is a package manager that can be found in the menu.
Hope this helps.
http://www.tuxradar.com/content/newbies-guide-fedora-12
weird psu problem siddharth_bhal Hardware Q&A 5 11-07-2010 04:14 PM
Problem with Soundmax Audio Driver Amitava83 Software Q&A 0 14-04-2010 10:41 AM
Screeching problem raviramgopal Hardware Q&A 0 07-04-2010 12:06 PM
"Thriller" Fedora 8 DukeNukem Open Source 11 22-11-2007 04:22 PM
Fedora 8 Test 2 Released: Compiz Fusion on the Go! Dark Star Open Source 4 15-09-2007 06:12 PM
