Old 19-07-2005, 04:13 PM   #1 (permalink)
Default Convert DVD movies to AVI SETTING.. NEED HELP
I have many movies on DVD ..which i want to convert to AVI files.
which software should i use..
which can give me give me small size avi like 450 to 600MB.
also the quality should be good enough to view in full screen
what should be the setting..
i.e. resolution, video codec, audio codec, audio kbps, sampling rate..
can any body provide me with these settings...
Thanks.
Alive_Hunter is offline
Old 20-07-2005, 11:03 AM   #2 (permalink)
Default Re: Convert DVD movies to AVI SETTING.. NEED HELP
Try dvd::rip and avidemux - these are the BEST Linux tools to get ur job done. Or u may run DVD Shrink or any other such Windows software under Wine.
Hope this helps.
coolblue is offline
Old 20-07-2005, 11:10 PM   #3 (permalink)
desertwind's Avatar
use dvd::rip. its the best available
www.exit1.org/dvdrip
Me use the following settings for dvdrip
Container: AVI
Video Codec: ffmpeg
ffmpeg codec: MPEG4
Video framerate: 23.976 fps
Video bitrate: 1000 kbps
Audio Codec: MP3
Bitrate: 128 kbps 48000 Hz
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
