Old 16-06-2010, 11:36 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
Default [Solved] Arch Linux and my Xorg Woes.
Hi all,
After sometime I decided to get Arch back on my system. So I downloaded the 64 bit version and then followed the Beginner guide all the way to the part of where you have to install Xorg.
Now first of all before I continue let me add my system information here.
AMD Phenom 550 BE
2 GB RAM
PATA 80 GB
SATA 80 GB
SATA 500 GB
Viewsonic VA 1918wm 1440 x 900 Resolution
Ati 5670
Now I managed to get everything working up till this point but getting the Ati card to work for me has been a pita.
I followd the steps where I have installed the following
xf86-video-ati
xorg
ati-dri
mesa
libgl
When I run Xorg -configure it configures a Xorg.conf.new in my home folder which I can test using the X -config command I think. and on doing so my systems returns a pitch black screen . Any ideas on how to continue at all? Thanks in Advance.
Id love to post the Xorg.conf file and any other details but I don't have access to a live disk and I'm stuck on the command prompt in Linux so I guess I could if it was urgent and there isn't anything else simple worth trying.
FilledVoid is offline   Reply With Quote
Old 16-06-2010, 11:47 AM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Default Re: Arch Linux and my Xorg Woes.
What's your driver in xorg?
kalpik is offline   Reply With Quote
Old 16-06-2010, 12:38 PM   #3 (permalink)
The Unknown's Avatar
Paste the xorg.conf at some pastebin service using wgetpaste. Its in the repos.
Just do cat xorg.conf.new | wgetpaste
It will give you a paste.pocoo.org link
KDE on ArchLinux
The Unknown is offline   Reply With Quote
Old 16-06-2010, 04:41 PM   #4 (permalink)
Sami Hyypiä, LFC legend
Liverpool_fan's Avatar
Have you installed and are running HAL?
You need to have HAL running for Xorg not to freeze
Experience true education in Computer Science - http://www.udacity.com | http://www.coursera.org
Read before asking / messaging any moderator for any query: FAQ + answers for new members
Don't use forum for chatting. Visit http://webchat.freenode.net/?channels=krow, enter nick and connect.
Liverpool_fan is offline   Reply With Quote
Old 16-06-2010, 05:16 PM   #5 (permalink)
Ah yeah, good point. I'd seen many discussions on the mailing list about HAL and Xorg. Ultimately those with the black screen didn't have HAL.
I think the latest xorg 1.8 depends on UDEV and not HAL
KDE on ArchLinux
Old 16-06-2010, 06:28 PM   #6 (permalink)
FilledVoid's Avatar
Default Arch Linux and my Xorg Woes.
Haha Im so sorry for being late to post this but I actually got the problem resolved. however I could never manage to get X tested using the X -config /root/Xorg.conf.new command which is what is written in the guide. After tryign out a few things with Kalpiks help I just went ahead and deleted Xorg and rebooted and everything worked fine lol. At the moment Im on Gnome on a Arch box which at the most is taking around 230 MB with all programs open . Ill mark this problem as solved so no one stumbles on it again !
Thanks for everyones input.
PS As for the disk issue I was having in another thread this time I didnt even bother to manual format . Just went and let the installer automatically partition it and everything is working great . Obviously I botched something up there.
Old 15-07-2010, 05:28 PM   #7 (permalink)
vignesh's Avatar
Default Re: [Solved] Arch Linux and my Xorg Woes.
Just curious, Any of you have problems with flash in Arch Linux ? I find flash a bit choppy only on Arch but html5 works great. I checked on the irc and many of them seemed to have this problem as well and wanted to me tell them if I found a solution.
vignesh is offline   Reply With Quote
Old 03-11-2010, 07:25 PM   #8 (permalink)
now hal is not needed to run X and also no xorg.conf is required for intel based graphics chip. no problem with flash here. If you have some specific site with problem post it.
kgas is offline   Reply With Quote
Old 04-11-2010, 04:30 PM   #9 (permalink)
X doesn't need HAL anymore, but there are still some packages that will not run without hal e.g gnome-terminal depeds on gnome-vfs which in turn depends on hal.So you still need HAL on your system even with latest Xorg.
iTwenty is offline   Reply With Quote
LinkBack to this Thread: http://www.thinkdigit.com/forum/open-source/128274-solved-arch-linux-my-xorg-woes.html
post your xorg.conf arch linux - Google Search This thread Refback 21-04-2011 10:20 PM
