Old 17-07-2005, 01:45 PM   #1 (permalink)
Default LOG IN problem in SUSE 9.1
my computer crushed while i was working in Suse and then wen i restarted computer KDE didnt load but instead console appeared and it said: Login:
and then i typed my user name and password and after that it said: "Have fun!" or something like that and still didnt load KDE. Im now only able to type in black like night console ..... help me
by the way same thing happened to Mepis 3.3 when i instaled it...
zerohourkill is offline
Old 17-07-2005, 02:10 PM   #2 (permalink)
You can type "startx" in the console to start X Windows.
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
ujjwal is offline
Old 18-07-2005, 05:15 PM   #3 (permalink)
What do u mean by your computer got crushed....was there an elephant in your house?!?
Neways, the answer ujjwal gave is right...you can also type "init 5" in the boot options that GRUB presents you with (thats in case u r using GRUB and not LILO). init 5 is the boot-in-gui-mode, u can say.
Let the windows open and the penguins come in.
Regards,
Sanket Medhi.
e-freak is offline
Old 18-07-2005, 07:27 PM   #4 (permalink)
Also, if you want to permanently switch to a graphical login screen, check the file /etc/inittab
You will probably find a line like -
change it to
Assuming that init level 5 is the graphical login mode for your system.
ujjwal is offline
Old 18-07-2005, 08:55 PM   #5 (permalink)
One query...
I have used the switchdesk command to change between the environments on RedHat using the CLI. Is this command exclusive to RedHat or does it work on all distros?
Regards,
Sanket Medhi.
e-freak is offline
Old 19-07-2005, 10:41 AM   #6 (permalink)
FooBar Guy
GNUrag's Avatar
SwitchDesk is not there in Debian. It could be an unnecessary appendage.
http://web.gnuer.org
GNUrag is offline
Old 22-07-2005, 01:13 AM   #7 (permalink)
i found what was the problem...it happens every time i install ATI driver for Linux...
Old 24-07-2005, 09:07 PM   #8 (permalink)
vignesh's Avatar
HOw many logins (sessions) can a person have in Linux.
vignesh is offline
Old 24-07-2005, 09:09 PM   #9 (permalink)
vignesh's Avatar
HOw many logins (sessions) can a person have in Linux.i currently have 3
F1,F2,F3.Can a person have more.
vignesh is offline
Old 24-07-2005, 10:31 PM   #10 (permalink)
sba
Yes but not recommended above 63
http://www.faqs.org/docs/Linux-HOWTO...WTO.html#ss7.1
sba is offline
Old 25-07-2005, 11:25 AM   #11 (permalink)
FooBar Guy
GNUrag's Avatar
If you want to login to multiple GUI terminals, (that is F7, F8, F9 ....)
then use gdmflexiserver command to start a new Login session. Your older GUI session (F7) gets locked by the screensaver and another login screen opens in F8. But this feature is available if you have GNOME installed.
GNUrag is offline
