Old 20-05-2010, 12:24 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Exclamation Ubuntu 10.04 "Low Graphics Mode" problem after update
Hey friends, after I updated my ubuntu and restarted I get new boot menu
http://img684.imageshack.us/i/image0008x.jpg/
I went on with the first one as it is the updated version which I did recently. I faced "Low Graphics Mode" Problem. After that I thought there might be some problem with the new one but I face this problem with the existing one too.
Here is a screenshot of what I get after selecting the 1st or 3rd one.
http://img208.imageshack.us/i/image0009s.jpg/
After pressing OK, I see this...
http://img17.imageshack.us/i/image0010d.jpg/
Now after this screen no matter what I do I don't the GUI. I've tried all the options there.
The first and last option takes me to this screen http://img576.imageshack.us/i/image0012p.jpg/ and keeps loading with no result.
Later from Windows I tried searching for the problem and get some solution in ubuntu forum...
starx
After running this command I saw initialization of GUI in KDE but after that blank screen. Nothing came atall.
sudo dpkg-reconfigure xserver-xorg
After running this command it says how to use dpkg and to use the help.
But nothing worked.
After spending some time in google it seems that the problem is for NVIDIA Driver Update. Though I didn't found any solution and it seems like the solutions were for previous versions not for Lucid Lynx.
For reference I'm adding my configuation:
Intel Pentium D
Intel D945GCCR
1GB DDR2 Transcend RAM
WD 160GB HDD
XFX 9500GT 1GB DDR2
LG DVD Writer
I installed Ubuntu 10.04 from Live CD(GNOME). And was using it since few weeks. After many days I booted into Windows 7. Please help to get back my Ubuntu.
UPDATE
After posting this I just restarted and went to ubuntu to see if anything can be done
Now I get new error message in Low Graphics Mode error dialog box
http://img175.imageshack.us/i/image0011g.jpg/
I tried the recovery mode too...and tried the "failsafe graphics mode". But it didn't worked.
Then I went to console and typed
sudo dpkg-reconfigure -a xserver.xorg
and get this...
http://img26.imageshack.us/i/image0013dt.jpg/
http://img526.imageshack.us/i/image0014e.jpg/
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is offline
Old 20-05-2010, 11:16 AM   #2 (permalink)
change is constant!!
khmadhu's Avatar
Default Re: Ubuntu 10.04 "Low Graphics Mode" problem after update
try to download and install nvidia drivers.. from nvidia site
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
khmadhu is offline
Old 20-05-2010, 11:21 AM   #3 (permalink)
Simply a DIGITian
^^How?? I'm not getting the GUI.
Old 20-05-2010, 03:22 PM   #4 (permalink)
khmadhu's Avatar
try this...
first install this tools
apt-get install envyng-qt envyng-core
then type
envyng -t
u will get a textual interface to install nvidia or ati drivers..
to check whether driver installed or not use this command..
lshw -c video
if still u r facing problem.. then try these steps..
https://help.ubuntu.com/community/Video
khmadhu is offline
Old 22-05-2010, 10:07 PM   #5 (permalink)
The Boy Who Lived
hjpotter92's Avatar
I am unable to install any version of Linux using the bootable from Digit/Chip/other mags. Each of them hangs at the same spot... the screen when it asks how to install UBUNUTU.
Core i7 920 @ 2.67 GHz
Intel DX58SO
3 GB DDR3 1600 MHz RAM
nVIDIA GeForce 9600 GS
Razer Arctosa + Abyssus
Please help: http://www.thinkdigit.com/forum/prog...p-windows.html
hjpotter92 is offline
Old 22-05-2010, 10:16 PM   #6 (permalink)
Simply a DIGITian
@khmadhu Well...Thnx. But I re-installed it and updated it. And it's working now.
---------- Post added at 10:16 PM ---------- Previous post was at 10:15 PM ----------
@hjpotter92 What's your system configuration?? Test your RAM's with memtest86+. You'll find it in Ubuntu Live CD. Seems like there is a problem with your RAM / Graphics.
Old 23-05-2010, 05:35 AM   #7 (permalink)
Linoob
celldweller1591's Avatar
Seems like you are having Kernel freeze. Try booting the LiveCD after selecting acpi=off. To do so, when ubuntu boots live, it asks you to select language, after selecting,language, press f6 before doing anything and select acpi=ff and then boot into live and see if ubuntu runs properly !
root@Celldweller#ping www.linoob.com
Ubuntu User # 31222
Linux User # 516252
celldweller1591 is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/open-source/127086-ubuntu-10-04-low-graphics-mode-problem-after-update.html
مشكلة بعد تشغيل باك ترك5 This thread Refback 24-04-2012 08:12 PM
Btrfs May Be The Default File-System In Ubuntu 10.10 celldweller1591 Technology News 4 16-05-2010 06:20 PM
Unable to install Ubuntu 9.10 - screen flickers Suhas Open Source 10 16-05-2010 05:13 PM
Dell to ship Ubuntu 7.10 on desktops and laptops CadCrazy Open Source 6 21-10-2007 10:44 PM
Extensions and Their Definitions Sparsh007 QnA (read only) 3 28-11-2006 07:25 PM
AutoPatcher for Windows XP SP 2 - August 2006 - Full, Lite & Update rajat22 Software Q&A 7 17-10-2006 10:24 PM
