Old 11-07-2005, 02:49 PM   #1 (permalink)
Default FC3 Help
i upgraded to FC3 from suse 9 and found it to b much much better but i still am a newbie at linux and so i did the unthinkable installed Xp only thn did i realise my mistake and now i am unable to boot into FC3 and neither do i have the digit dvd nor the Cdz from which I installed FC3 so plzz help me boot bak into FC3 plzzzz all partitions are still intact
adityaksharma is offline
Old 11-07-2005, 05:41 PM   #2 (permalink)
gauravnawani's Avatar
Boot from the first fedora disk,
Select rescue mode.
When it drops you at the prompt then issue
chroot /mnt/sysimage
grub-install <device> hda
Make sure you know on which harddisk you had installed both of them. Typically hda will be the first hardisk and hdd second and so on.
You can buy the Linux for you of this month it contains Fedora4 DVD.
Blender India forums
http://www.bestfreeforums.com/forums/blenderindia.html
gauravnawani is offline
Old 11-07-2005, 06:05 PM   #3 (permalink)
desertwind's Avatar
@gaurav
he already told that he do not have the install disk with him. do you have any other solutions ?
@aditya
download the fc3 net install iso, its about 5 mb. burn it to a cd, and follow the steps quoted by gaurav
http://fedora.lsu.edu/dist/linux/core/3/i386/os/images/boot.iso
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
Old 12-07-2005, 06:56 AM   #4 (permalink)
Originally Posted by desertwind
@gaurav
>> Re read the post please.
You can buy the "Linux for you" of this month it contains Fedora4 DVD.
Old 12-07-2005, 02:39 PM   #5 (permalink)
Well if you cannot get hold of a Fedora disk, you can do without it. Boot into any live cd that supports your hardware and filesystem used (AFAIK fedora uses ext2 or ext3, so this should not be a problem), mount the partition which contains /boot, on a directory, if the hard disk is hda1, use
mkdir /mnt/fedora
mount /dev/hda1 /mnt/fedora
chroot to /mnt/fedora and proceed as gaurav explained.
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
ujjwal is offline
Old 12-07-2005, 03:20 PM   #6 (permalink)
desertwind's Avatar
Oops! Sorry!!!
