Old 19-03-2010, 12:38 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Stuck
Default Problem installing linux(s)
Hi !
I currently have Win Vista installed on my machine having config:
C2D 2.0GHz, 2.5gigs ddr2 ram, 160g hdd, mercury 945gzd mobo
I came up from a major virus crisis, due to which I had to repartition my whole hdd. What the virus did was that it used to crash the 'Generic driver for win32 processes' in XP and gave me blue screen errors in vista/7. Both happened only when I used internet on my system.
After installing Vista, I tried installing different distros of linux but:
# Open Solaris ends up in a command line login screen,
# Linux mint some command promp with
ramfs>
as prompt,
# ubuntu(9.10,8.10,8.04) & kubuntu(9.10) get hanged after the initial loading screen (both live n installation)(though the "ctrl+alt+del" still works in the hanged up state),
# openSUSE(11.1) after intial loading screen ends up in a kernel menu, where if I try installing it with a CD/DVD source, it says
No repositories found
Please help me out, I've installed all of these before and have never faced such a problem.
Nokia 3500c, LG Optimus One P500
DELL INSPIRON 15R, Core i5 (2.53-2.8), 4Gb DDR3, 500Gig HDD 5400, 512Mb HD5470
Vivek.28 is offline
Old 19-03-2010, 01:52 AM   #2 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
Default Re: Problem installing linux(s)
Considering that Ubuntu is one of the distros with a big end user base and that Im using it Ill see if I can help you with it.
First of all where are you exactly getting the error. Were you able to install Ubuntu or did it crash when you used the Live CD/DVD. I'm guessing that it might have something do with APIC or ACPI . You could try disabling both and see if it allows you to install Ubuntu.
FilledVoid is offline
Old 19-03-2010, 10:23 AM   #3 (permalink)
yup, you need to try booting the live CD with the acpi=off parameter.
Here's how it's done:
ico is offline
Old 19-03-2010, 10:48 PM   #4 (permalink)
Stuck
I tried the ACPI method but got the following result:
BusyBox v1.13.3(ubuntu 1:1.13.3-1ubuntu7) built-in shell(ash)
(initramfs)unable to find a medium containing a live file system
As far as I can understand from this, the live image isn't able to run off from the CD/DVD, so the shell is initiating a ram file system. Now this problem is the same as in case of Linux mint 7.
What should I do now ? I am totally confused.
Vivek.28 is offline
Old 20-03-2010, 06:52 PM   #5 (permalink)
Could it be that your CD/DVD drive's got a problem...try making a bootable USB and install using that..go to pendrivelinux.com for details on how to do that..you'll need a min 1 GB pendrive
Registered Linux User #470917 || I haven't lost my mind -- it's backed up on tape somewhere.||
aashish.joshi is offline
Old 20-03-2010, 07:02 PM   #6 (permalink)
okay, this might help you. http://unetbootin.sourceforge.net/
Install using that.
ico is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/open-source/125191-problem-installing-linux-s.html
Google INTERIA.PL - szukaj: unable to find a medium containing a live file system This thread Refback 22-04-2011 10:31 PM
Is a swap partition necessary while installing Suse? Arun the Gr8 Open Source 11 16-07-2010 05:43 AM
Installing Multiple CD Drives darnee Hardware Q&A 2 01-02-2010 10:11 PM
Installing Problem gapchoo009 QnA (read only) 1 25-03-2008 12:48 PM
Installing BitDefender problem.. //siddhartha// Open Source 8 14-05-2005 08:56 AM
Problem in installing mplayer in fedora3 neerajvohra Open Source 2 16-02-2005 01:08 AM
