Old 08-01-2010, 01:12 AM   #1 (permalink)
.:: 3 : 1 6 ::.
anish_sha's Avatar
Question How to create a RECOVERY DISK using Acronis True Image
i just wanna create a recovery disk including my windows OS with all the drivers and softwares installed as of now, it should be exactly like the recovery disks we get along with a laptop.pls help me how to create it, i just installed Acronis True Image, but confused how to create it.. someone pls help
anish_sha is offline
Old 08-01-2010, 11:53 AM   #2 (permalink)
.:: 3 : 1 6 ::.
anish_sha's Avatar
Default Re: How to create a RECOVERY DISK using Acronis True Image
someone help pls..................
Old 09-01-2010, 04:27 PM   #3 (permalink)
Married!
Rahim's Avatar
You should create a bootable Acronis CD whereby you dont have to install the program itself to backup partions. You can boot with this cd and it can be used in other PCs as well.
Coming to your query, create a full backup of your C: (windows) drive and when you reach the various options, you can specify the size of the backup image (700MB/4GB) so that you can burn them on cd/dvd as per the requirements.
I dont know what type of recovery cds are provided with laptops.
|| GNU/Linux User || PCLOS KDE 4.6 || 17" DELL Studio ||
topdocumentaryfilms.com
Rahim is offline
Old 11-01-2010, 12:47 PM   #4 (permalink)
live life king like...
hot zubs's Avatar
had tried acronis software long back, but it never worked with me, tried many times but process of writing the data on DVD never completed, an error comes and d process stops...
is there anyone who has tried Acronis, plz giv us a step step by procedure of it...
Core i5 2400, Intel DH67BL-B3, 2GB Corsair DDR3, Geforce 8600GT, Seagate 1TB, LG 20x , BenQ E2220 HD, Creative M4500 , CM extreme 600W, CM 690, APC BackUPS -ES650VA
hot zubs is offline
Create sepia tone image with photoshop SWEET SNEHA Tutorials 5 11-11-2005 08:12 PM
What is the Windows XP Password Reset Disk and how can I use stalin Software Q&A 2 15-05-2005 05:54 PM
Use "Windows" your own way ! rajkumar_personal Software Q&A 6 26-02-2005 11:40 PM
Bizzy's Guide to Good Hard Drive Maintenance bizzyboy QnA (read only) 3 29-12-2004 09:50 PM
