Old 09-12-2009, 07:54 PM   #1 (permalink)
bbalegere's Avatar
Default Mount UDF ISO in Ubuntu
Gmount-iso, AcetoneIso ,Furius ISO Mount and Archive mounter are tools to mount ISO images in Ubuntu.
However none of them can mount a UDF ISO images it correctly.The mount folder contained a single file called readme.txt
This disc contains a “UDF” file system and requires an operating system that supports the ISO-13346 “UDF” file system specification.
So I have made 2 shell scripts to mount and unmount UDF and normal Joilet ISO images in Ubuntu
You can read the full tutorial and the mount.sh and unmount.sh code here
http://agnipulse.com/2008/08/easily-...ves-in-ubuntu/
AgniPulse.Com - Undocumented Tech Tips
bbalegere is offline
Old 10-12-2009, 10:57 PM   #2 (permalink)
BSD init pwns System V
hellknight's Avatar
Default Re: Mount UDF ISO in Ubuntu
wouldn't this work :-
sudo mount -o loop -t UDF filename.iso mountpoint
My blog :- www.openenclave.wordpress.com
hellknight is offline
Old 10-12-2009, 11:19 PM   #3 (permalink)
Cool G5's Avatar
Post Re: Mount UDF ISO in Ubuntu
Yes, I too feel the same.
Cool G5 is offline
Old 11-12-2009, 05:59 AM   #4 (permalink)
bbalegere's Avatar
No this does not work.I tried it.This command cannot mount any type of image,UDF or even normal iso images.
But when you use auto the same script can mount both UDF and normal ISO images.
Old 11-12-2009, 11:42 PM   #5 (permalink)
hellknight's Avatar
It mounts ISO images.. i've been using this command since ages to mount the standard ISO9660 images to mount in Linux.. it works under any Linux distro.. This command works..
Offline Ubuntu Package Center CadCrazy Open Source 137 16-02-2009 04:13 PM
Ubuntu Customization Guide v2.. Dark Star Open Source 66 19-08-2008 02:32 PM
Ubuntu Scores First Major Pre-installed Server Win CadCrazy Technology News 3 16-11-2007 01:56 PM
Dell to ship Ubuntu 7.10 on desktops and laptops CadCrazy Open Source 6 21-10-2007 10:44 PM
Knoppix Live cd - grt.. nething better ? Open Source 17 10-02-2005 08:14 PM
