Old 09-12-2009, 06:06 PM   #1 (permalink)
Cool G5's Avatar
Question Need distro for old PC
My PC specs are as follows:
P4 2.0GHZ
MSI PM8M-V Motherboard
Onboard Via P4M800 Graphic Chip
512MB DDR RAM
I need a distro for the above machine. I tried Ubuntu 9.10, Fedora 12 LXDE but both of them feel slow. I went to install Arch but it failed to boot giving a GRUB error i.e. Grub hanging at stage 2. My optical drives are most reason for not able to install the GRUB properly. What should I try next? Gentoo? I'll need the distro for basic work since given my config it won't allow me to do other heavy stuff. I personally favor KDE but then again due to low on resources I need to settle on other light weight DE. Which one do you suggest? Also how can I check whether my computer supports booting via USB or not?
Cool G5 is offline
Old 09-12-2009, 08:09 PM   #2 (permalink)
Crowman
Krow's Avatar
Default Re: Need distro for old PC
Sabayon 5 ?
Linux Mint 7 Gloria? Helena is based on Karmic, so I assume it would be slower.
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 09-12-2009, 08:40 PM   #3 (permalink)
Cool G5's Avatar
Sabayon 5, no way. It will crawl.
Linux Mint 7 won't be a good choice either since based on GNOME its sure to hog 170MB RAM when idle since that's the amount of ram which Ubuntu 9.04 & Ubuntu 9.10 hogs on my system. I need something really light. Tried Fedora 12 LXDE but it too seems to take 160MB of RAM when idle. Not much improvement considering the LXDE environment. I would anyday move over to GNOME then.
Cool G5 is offline
Old 09-12-2009, 09:31 PM   #4 (permalink)
Married!
Rahim's Avatar
Why dont you go with XFCE/LXDE on Arch? If you don't like configuration Arch, then install Debian and use a WM rather than a whole DE. This would reduce the resource hogging.
I have the same system as yours and it runs KDE4 in Debian & Arch very well. I don't know why you think GNOME is the only resort for your system?
|| GNU/Linux User || PCLOS KDE 4.6 || 17" DELL Studio ||
topdocumentaryfilms.com
Rahim is offline
Old 09-12-2009, 10:20 PM   #5 (permalink)
Perhaps Puppy Linux or Damn Small Linux will be suitable? If you press F8 during bootup, do you get option for choosing boot device? If so, you can insert USB bootable device like bootable pendrive and see if it is recognised... If not, you may have to search the BIOS menus for seeing if usb boot is supported...
Arun
sakumar79 is offline
Old 09-12-2009, 11:06 PM   #6 (permalink)
Cool G5's Avatar
Post Re: Need distro for old PC
Thinking of the same. Arch + LXDE.
So what do you suggest Arch + LXDE or Arch + KDE?
Cool G5 is offline
Old 09-12-2009, 11:25 PM   #7 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
Arch is my choice. However there are dozens of other options. Ive been using an OS called NimbleX for sometime now on two low end systems its got some problems but it does its job as intended at a small memory cost. Puppy seems to be a fine choice also btw.
If you really want to go Hardcore check out articles on trimming Ubuntu by loads. Search for Kmandla .
FilledVoid is offline
Old 10-12-2009, 12:08 AM   #8 (permalink)
Cool G5's Avatar
@Filledvoid - I have already thought of trimming some distro. First thing I do today will be to try installing some distro on my PC. The optical drives are giving problems & I'm not sure whether it supports usb booting. If it doesn't work then, I would be installing Fedora 12 LXDE or Ubuntu 9.10 & think of trimming them up like you pointed out.
BTW I installed Arch yesterday but after I rebooted the PC hangs at GRUB Stage 2. WHile installing the GRUB the PC threw some Buffer I/O Errors(Mostly since my optical drive has aged or I suspect bad sectors on my HDD). WHat can I do to clear it out? I'm not even able to boot via Arch CD anymore.
Cool G5 is offline
Old 10-12-2009, 08:19 AM   #9 (permalink)
FilledVoid's Avatar
See if you can boot anything at all. If you can just wipe the disk clean and try again would be my suggestion but wait for others opinion also . They might have a better idea.
Old 10-12-2009, 11:41 AM   #10 (permalink)
99.9% Idle
axxo's Avatar
chakra should do for you, based on arch and most pleasing KDE.
or one of the other arch based distros.
http://wiki.archlinux.org/index.php/Arch-based_Distros
---------- Post added at 11:41 AM ---------- Previous post was at 11:41 AM ----------
Unban praka123
axxo is offline
Old 10-12-2009, 08:50 PM   #11 (permalink)
Married!
Rahim's Avatar
I dont see any slowdown with KDE4 both in Debian and Arch. Infact its quite steady and speedy; of course it cant match the speed of other light DEs.
Rahim is offline
Old 10-12-2009, 10:21 PM   #12 (permalink)
Cool G5's Avatar
Ok, I purchased a new DVD writer & now I have successfully installed Arch Linux.
But when I tried connecting to web I got;
failed to init transaction (unable to lock database)
if you're sure a package manager is not already running, you can remove var/lib/pacman/db.lck
I'll try removing the file mentioned in the error & report back.
Cool G5 is offline
Old 11-12-2009, 11:12 AM   #13 (permalink)
Married!
Rahim's Avatar
^Sometimes a background application keeps running, like Update Notifier which locks access to packages database. So deleting that file and then using pacman will solve the problem.
If you are installing Arch then use irrsi for irc chat in the konsole itself. This way you can get help on freenode and us along with your installation process
Much better way then rebooting to other distro to get help.
Rahim is offline
Old 11-12-2009, 11:20 AM   #14 (permalink)
Cool G5's Avatar
But I'm not sure whether network works or its the pacman issue. Also never used irc via konsole. WIll have to read up on it.
Cool G5 is offline
Old 11-12-2009, 11:26 AM   #15 (permalink)
Married!
Rahim's Avatar
^irssi is simple. Just start it with 'irssi' and then enter '/server irc.freenode.net' to connect.
Do you use BSNL Dataone? If yes then its very simple. Use pppoeconf to configure your ADSL network. Then you have to execute this command to connect.
/etc/rc.d/adsl start and /etc/rc/d/adsl stop to disconnect. You have to be 'root' to do that.
Rahim is offline
Old 11-12-2009, 03:29 PM   #16 (permalink)
Cool G5's Avatar
I'm now stuck with enabling internet in Arch. Refer this thread : http://bbs.archlinux.org/viewtopic.php?id=86540
Cool G5 is offline
Old 11-12-2009, 03:38 PM   #17 (permalink)
Married!
Rahim's Avatar
^I can help you if you come on irc.freenode.net #krow
Use irssi .
This is my /etc/rc.conf
# /etc/rc.conf - Main Configuration for Arch Linux
# LOCALIZATION
# LOCALE: available languages can be listed with the 'locale -a' command
# HARDWARECLOCK: set to "UTC" or "localtime"
# USEDIRECTISA: use direct I/O requests instead of /dev/rtc for hwclock
# TIMEZONE: timezones are found in /usr/share/zoneinfo
# KEYMAP: keymaps are found in /usr/share/kbd/keymaps
# CONSOLEFONT: found in /usr/share/kbd/consolefonts (only needed for non-US)
# CONSOLEMAP: found in /usr/share/kbd/consoletrans
# USECOLOR: use ANSI color sequences in startup messages
LOCALE="en_US.utf8"
HARDWARECLOCK="localtime"
USEDIRECTISA="no"
TIMEZONE="Asia/Kolkata"
KEYMAP="us"
CONSOLEFONT=
CONSOLEMAP=
USECOLOR="yes"
# HARDWARE
# MOD_AUTOLOAD: Allow autoloading of modules at boot and when needed
# MOD_BLACKLIST: Prevent udev from loading these modules
# MODULES: Modules to load at boot-up. Prefix with a ! to blacklist.
# NOTE: Use of 'MOD_BLACKLIST' is deprecated. Please use ! in the MODULES array.
MOD_AUTOLOAD="yes"
#MOD_BLACKLIST=() #deprecated
MODULES=(!usblp)
# Scan for LVM volume groups at startup, required if you use LVM
USELVM="no"
# NETWORKING
# HOSTNAME: Hostname of machine. Should also be put in /etc/hosts
HOSTNAME="localhost"
# Use 'ifconfig -a' or 'ls /sys/class/net/' to see all available interfaces.
# Interfaces to start at boot-up (in this order)
# Declare each interface then list in INTERFACES
# - prefix an entry in INTERFACES with a ! to disable it
# - no hyphens in your interface names - Bash doesn't like it
# DHCP: Set your interface to "dhcp" (eth0="dhcp")
# Wireless: See network profiles below
eth0="eth0 192.168.1.2 netmask 255.255.255.0 broadcast 192.168.0.255"
#eth0-"dhcp"
INTERFACES=(eth0)
# Routes to start at boot-up (in this order)
# Declare each route then list in ROUTES
# - prefix an entry in ROUTES with a ! to disable it
gateway="default gw 192.168.1.1"
ROUTES=(!gateway)
# Enable these network profiles at boot-up. These are only useful
# if you happen to need multiple network configurations (ie, laptop users)
# - set to 'menu' to present a menu during boot-up (dialog package required)
# - prefix an entry with a ! to disable it
# Network profiles are found in /etc/network.d
# This now requires the netcfg package
#NETWORKS=(main)
# DAEMONS
# Daemons to start at boot-up (in this order)
# - prefix a daemon with a ! to disable it
# - prefix a daemon with a @ to start it up in the background
DAEMONS=(syslog-ng hal fam alsa @network kdm netfs @crond )
So you might use Static IP and check the Gateway and then configure your DSL with pppoeconf
Rahim is offline
Old 11-12-2009, 04:45 PM   #18 (permalink)
Cool G5's Avatar
I have uncommented the gateway by removing the !.
Now look at the output of "route" command,
Cool G5 is offline
Old 12-12-2009, 04:31 PM   #19 (permalink)
Married!
Rahim's Avatar
Beginners' Guide
Look under 2.9.2.3 NETWORKING Section
Rahim is offline
Old 12-12-2009, 10:59 PM   #20 (permalink)
Cool G5's Avatar
I get the following when Arch is booting up.
And here is the content of my /etc/rc.conf;
# LOCALIZATION
LOCALE="en_US.utf8"
HARDWARECLOCK="UTC"
USEDIRECTISA="no"
KEYMAP="us"
CONSOLEFONT=
CONSOLEMAP=
USECOLOR="yes"
# HARDWARE
MOD_AUTOLOAD="yes"
MODULES=()
USELVM="no"
# NETWORKING
HOSTNAME="CoolG5"
#Static IP example
#eth0="eth0 192.168.0.2 netmask 255.255.255.0 broadcast 192.168.0.255"
eth0="dhcp"
INTERFACES=(eth0)
ROUTES=(!gateway)
NETWORKS=(main)
# DAEMONS
DAEMONS=(syslog-ng network netfs crond portmap fam dbus hal !avahi-daemon)
Cool G5 is offline
Old 13-12-2009, 12:05 AM   #21 (permalink)
Married!
Rahim's Avatar
^Why not use static ip and see if it works?
Rahim is offline
Old 13-12-2009, 11:42 AM   #22 (permalink)
Cool G5's Avatar
Which IP should I use? I'm very bad when it comes to networking. DNS, Gateways all goes like a bouncer for me.
Cool G5 is offline
Old 13-12-2009, 12:20 PM   #23 (permalink)
Married!
Rahim's Avatar
I have been telling you all along. See Post#17 above. Those highlighted lines should work.
Then configure Network (read Post#15).
OFF TOPIC: My system freezes with intel drivers on Arch
Rahim is offline
Old 13-12-2009, 01:14 PM   #24 (permalink)
Cool G5's Avatar
Here is what I get after I tried editing the line as shown in #17.
Also pppoeconf returns with command not found.
Cool G5 is offline
Old 13-12-2009, 01:37 PM   #25 (permalink)
Married!
Rahim's Avatar
^hehe
Once you get online then use pacman
You dont have any serious problem. Just need the eth0 unterface to setup.
ifconfig -a will give you whether your ethernet (eth0) is up and running . But it seems its down.
/sbin/ifconfig eth0 up will bring eth0 interface up and will assign the static ip as in rc.conf file
As for pppoeconf, have you installed rp-pppoe package?
Rahim is offline
Watch out for these upcoming PC titles Harvik780 Gamerz 718 18-12-2009 07:31 AM
We offer APPLE G4 POWERBOOK 1.5GHZ SUPERDRIVE WITH 15 INCH DISPLAY........$700 pdaworldltd Chit-Chat 2 02-09-2007 10:23 PM
Linux Distro Guide webgenius Tutorials 1 27-02-2007 02:41 PM
Nokia Pc Suite Not Detecting My 3230 Phone!! Plzzzzz Help Me*** kool Mobiles and Tablets 11 24-10-2006 10:26 AM
Connect TV to Pc blademast3r Tutorials 17 23-10-2006 04:59 PM
