Old 13-08-2009, 08:40 PM   #1 (permalink)
geek........
Gauravs90's Avatar
Question Help with Linux
I've installed ubuntu 8.04
I'm new to linux
I've downloaded firefox-3.5.2.tar.bz2 and don't know how to install it pls help
Gauravs90 is offline
Old 13-08-2009, 11:10 PM   #2 (permalink)
Default Re: Help with Linux
^Downloaded from firefox's website? Then you just need to uncompress the file and run the firefox script.
ThinkFree is offline
Old 14-08-2009, 06:42 AM   #3 (permalink)
TheSaint
NucleusKore's Avatar
Ubuntu 8.04, that's outdated.
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 14-08-2009, 09:20 AM   #4 (permalink)
geek........
Gauravs90's Avatar
Which linux should i use? Which is the best linux?
Old 14-08-2009, 09:27 AM   #5 (permalink)
TheSaint
I would recommend Ubuntu 9.04
However, it would be wise to go through the list of FAQ
Frequently Asked Questions (FAQ's)
Old 14-08-2009, 10:16 AM   #6 (permalink)
What? Where? How?
escape7's Avatar
Use Ubuntu 9.04.
And download it in .deb format. Its easier.
t'll take time for you to get used to ubuntu but u'll like it later on. And search the web on how to install, u'll get proper steps.
98% of the people using internet have started or forwarded "chain mails". If you are one of the 98%, Die a horrible death.
escape7 is offline
Old 14-08-2009, 10:51 AM   #7 (permalink)
geek........
Gauravs90's Avatar
Originally Posted by escape7 View Post
Use Ubuntu 9.04.
ya i will download ubuntu 9.04. I've used windows for 5 yrs and very keen to learn linux now.
I don't want to install ubuntu on seperate partition, i want to install it inside windows so i'Ve to download iso file.
Old 14-08-2009, 11:42 AM   #8 (permalink)
Cool G5's Avatar
So you will be installing under WUBI?
I recommend you learn a bit about partitioning & install it in a seperate partition soon.
Cool G5 is offline
Old 20-08-2009, 11:48 AM   #9 (permalink)
geek........
Gauravs90's Avatar
hi I've downloaded and installed ubuntu 9.04 by wubi.
The default browser is firefox 3.0.8, how can i upgrade this browser to firefox 3.5.2
Old 20-08-2009, 11:54 AM   #10 (permalink)
Cool G5's Avatar
Open a terminal & enter;
sudo apt-get install firefox
Cool G5 is offline
Old 20-08-2009, 03:17 PM   #11 (permalink)
geek........
Gauravs90's Avatar
with synaptic pakage manager in ubuntu i only able to upgrade firefox to 3.0.13
how can i install firefox 3.5.2?
