Old 26-07-2009, 03:22 PM   #1 (permalink)
harshitjain's Avatar
Default Amarok 2.1.1 problem !!
I recently upgraded to amarok 2.1.1 from 2.0.2......
the problem is whenever I try to run it, it starts updating system configuration and doesn't even stop after an hour.....
When I cancel the process, amarok it shows this
Amarok could not find any collection plugins. It is possible that Amarok is installed under the wrong prefix, please fix your installation using:
$ cd /path/to/amarok/source-code/
$ su -c "make uninstall"
$ cmake -DCMAKE_INSTALL_PREFIX=`kde4-config --prefix` && su -c "make install"
$ kbuildsycoca4 --noincremental
$ amarok
More information can be found in the README file. For further assistance join us at #amarok on irc.freenode.net.
I don't even know where is the path to amarok source code......
Please help........
harshitjain is offline
Old 27-07-2009, 11:21 PM   #2 (permalink)
Wandering In Tecno Land
Ecko's Avatar
Talking Re: Amarok 2.1.1 problem !!
completely remove it using synaptic
get a new amarok copy from http://amarok.kde.org/wiki/Download
re-install
BTW u never told wats ur distribution ??
Born in Windows Die In Linux © 2009-10 All Rights Reserved.
Learn Linux : www.linoob.com (Official WebSite)
Ecko is offline
Old 06-08-2009, 07:48 AM   #3 (permalink)
Default Re: Amarok 2.1.1 problem !!
re-installtion would not be the ultimate solution .. or would it be ?
<<<<<<<<<<<<<<<SaXaM>>>>>>>>>>>>
Saksham ghimire is offline
