Originally Posted by rollcage
since you saying that your primary os is Fedora than you choose Win7 as secondary, bcoz its better and the new build is very stable. almost all the software are supported. easily driver support.
between what config you have? are you using x64 or x86?
I use x86 processor Intel Pentium 4 3.06 Ghz. My RAM is 1.5 Gb and a 160 Gb HDD that too going low on space. I think you are right i must use win 7 instead of xp. good suggestion. Ok will decide after i will download Fedora 11.
But there is one problem that i m using Quick Heal Firewall in xp and i nearly know everything about this firewall as i m having a limited broadband connection (1.5 gb). So i have to limit my usage by blocking some programs through firewall in xp. But this firewall doesn't work in win 7. When i install it in win 7 then after shut down it shows Blue Screen of Death. I have also tried zone alarm firewall but that too not working in win 7. Also becoming expert in other firewall(if it will get installed) will take time and that's what i dont have. So if you can help me installing Quick Heal Firewall that will be good.
