Old 01-06-2009, 10:55 PM   #1 (permalink)
mera kutch nahi ho sakta
chesss's Avatar
Default HOw does Arch 'Roll'
Thinking of giving arch linux a try.
One thing concerns me. I read that arch is rolling update kind of distro . How exactly does this work ?
My concern is will I have to upgrade my system (while potentially breaking it ) every 3 months just to install the latest version of a package . I read that upgrading, just like other distros may not be smooth.
Basically it feels like a high-maintenance distro. One that might easily break.
What I really want to avoid is one of those distros in which a dist-upgrade could very well break your system. But the dist-upgrade is required to install the latest apps from the package manager.
jin files ka koi server nahi hota unka bittorrent hota hai
chesss is offline   Reply With Quote
Old 02-06-2009, 07:33 PM   #2 (permalink)
The Unknown's Avatar
Default Re: HOw does Arch 'Roll'
If you have experience of Linux then Arch won't break. Arch is very complicated to n00bs.
Get some experience with other user friendly distros and then move to Arch.
KDE on ArchLinux
The Unknown is offline   Reply With Quote
Old 02-06-2009, 08:18 PM   #3 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
I use arch and it has not broken ever, since several months back when I installed it.
And doing a System Upgrade here is perfectly alright and does not b0rk the PC.
I run the update command DAILY.
Unlike debian sid, which I think is the distro you are refering to which causes issues upon upgrading 1 in 10 times, arch only has stable updates and they are all 99.99% safe.
But don't join the arch club unless you have enough experience with linux. I recommend you to move to Debian Testing (Squeeze) first and try it for a few months. Install a minimal commandline system and then build the rest of the system from there. Once you do this you have gained valuble commandline experience. Then you can join the arch gang.
And BTW, arch has next to ZERO maintainence. Its also called the distro for lazy geeks.
Apple iPad 2 16GB WiFi
MetalheadGautham is online now   Reply With Quote
Old 02-06-2009, 10:29 PM   #4 (permalink)
chesss's Avatar
I got concerned after reading this post .
Nice to know this one doesn't break
Old 02-06-2009, 11:34 PM   #5 (permalink)
a_k_s_h_a_y's Avatar
I have arch, I used to update regulary, haven't updated for a while and it works just fine and very smooth.
Will go for complete re-install according to new needs !
Sony Ericsson Flashing, Modding, Patching, Hacking And More !
http://www.akshayy.com/sonyericsson/
a_k_s_h_a_y is online now   Reply With Quote
Old 03-06-2009, 12:52 PM   #6 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
I use arch.. And i do a system upgrade twice daily
And its totally noob friendly if you know how to read. The wiki is an awesome resource and everything is well documented.
People even run arch testing (which also considered VERY stable)! The only instability is in the unstable repo.. I myself use quite many packages from testing every now and then. Trust me, its a very nice distro
kalpik is offline   Reply With Quote
Old 03-06-2009, 12:52 PM   #7 (permalink)
kalpik's Avatar
Old 03-06-2009, 02:44 PM   #8 (permalink)
chesss's Avatar
well konqueror has crashed a few times already . But I am using kdemod, which isn't official
Old 03-06-2009, 03:05 PM   #9 (permalink)
kalpik's Avatar
Yup.. Use official KDE.. Though KDE4 in itself has some stability issues.. So you cannot blame it on arch
Old 03-06-2009, 06:36 PM   #10 (permalink)
chesss's Avatar
oh damn yet another distro with some obscure problem . With arch its random dropping of network! that or a random pause while downloading from the repo bug.
Besides I can't install Opera 10 beta 1 on it! formatting time...
Old 03-06-2009, 07:50 PM   #11 (permalink)
hullap's Avatar
ive never encoutered those 'bugs'
hullap is offline   Reply With Quote
Old 03-06-2009, 07:59 PM   #12 (permalink)
Nice !
Faun is online now   Reply With Quote
Old 03-06-2009, 10:17 PM   #13 (permalink)
kalpik's Avatar
Wow.. That's it? Great!
http://aur.archlinux.org/packages.php?ID=18994
Old 04-06-2009, 02:47 PM   #14 (permalink)
chesss's Avatar
^ Thanks, but thats not the beta version
Old 04-06-2009, 03:00 PM   #15 (permalink)
What exactly is Arch???
Would you mind giving some insight into Arch to a newbie?
Crazykiller is offline   Reply With Quote
Old 04-06-2009, 03:01 PM   #16 (permalink)
Default Arch Rolls on It's Back when we say "arob"
arob = Arch Rolling on Back
Old 04-06-2009, 07:50 PM   #17 (permalink)
kalpik's Avatar
yes. but you can just modify the PKGBUILD!
Old 04-06-2009, 07:51 PM   #18 (permalink)
kalpik's Avatar
wait.. someone did it! http://aur.archlinux.org/packages.php?ID=27001
Old 04-06-2009, 10:53 PM   #19 (permalink)
chesss's Avatar
^That is fast. I guess packages appear in Aur faster than in other distros community repos
Old 15-06-2009, 06:57 PM   #20 (permalink)
rb210
Posts: n/a
Arch + KDEmod is the best. There is an Arch derivative called Chakra which is basically an Arch + KDEmod livecd.
Old 31-08-2009, 06:49 PM   #21 (permalink)
Chess, wet your hands first. Don't use AUR first unless you know what your are doing. IMO Arch is having detailed documentation. pacman is very nice and best among all the distros. Arch won't bind your hands
kgas is offline   Reply With Quote
Old 31-08-2009, 10:42 PM   #22 (permalink)
chesss's Avatar
I have heard this statement for almost every distro. xyz's package manager is the best among all distros
Old 03-09-2009, 07:57 PM   #23 (permalink)
Married!
Rahim's Avatar
^All the package manager does the same thing: Download and install application
So which is better and which is not is not the main point.
|| GNU/Linux User || PCLOS KDE 4.6 || 17" DELL Studio ||
topdocumentaryfilms.com
Rahim is offline   Reply With Quote
- by Anorion
- by ax3
