I own a comp fitted with an amd athlon xp processor of 1.66gig,
asus a7n series motherboard.
I was very much eager to install linux into my comp.
I tried linspire ,but it can't be installed on to hard disk.
I finally found ubuntu linux on digit dvd of dec2004 with a caption of more than 1000 softwares.
So i burnt the iso file on a disc and started installation.
Every thing was going fine.
It detected my hardwares, it detected no network settings.
Then I gave it a fat32 partition of 7Gb sace to sit.
Designated it as root(/).
It began to get installed.
A window opened saying "installing the ubuntu base system ,validting"
It halted at 22% witha error" debootstrap progrm exited with a error
(return value 1).
"check /var/log /messages."
The only option that was workin in the installer was "abort installation and reboot" ,which when opened gave caution that system will be in a unstable state, which is now true.
I also checked cd's integrity and found no problem.
Now I can't complete installation and reboot into my old oses!!
When rebooted from hard disk it says "press a key to reboot"
please help me!
