Old 20-06-2005, 08:10 PM   #1 (permalink)
harmax's Avatar
Default a simple tool which i couldnt figure out in GIMP
simply put
HOW DO U REDUCE THE SIZE AN IMAGE IN GIMP ??
without makin changes to its size
i mean no altering 1024X768 to 800X600 etc
thnx in adv
WORK EXPANDS TO FILL THE TIME NEEDED FOR ITS COMPLETION
-------- PARKINSON\'S LAW
harmax is offline
Old 21-06-2005, 11:56 AM   #2 (permalink)
gauravnawani's Avatar
You mean zoomin the Image inside the window??
Try [-] Key or Zoom out
[Shift]+[+] for Zoom in
Or Simply View>>Zoom.
NOTE use the minus and plus key on the alphabet side of board.
Blender India forums
http://www.bestfreeforums.com/forums/blenderindia.html
gauravnawani is offline
Old 21-06-2005, 12:54 PM   #3 (permalink)
harmax's Avatar
sorry for not being clear
i meant reducing the size from something like 600KB to some lesser KB
harmax is offline
Old 21-06-2005, 06:41 PM   #4 (permalink)
That will depend on the type of format you want to save the file in.
If you want to use JPG then Gimp provides a dialog box just for that. To use it you have to save the file as [Save As] (dont save over the same file). Confirm exporting if the dialog pops up. Then in the next dialog box make sure you have enabled preview, and now you can change the quality of the image to reduce the Kb.
NOTE: If you are using Gimp2.2x you will need to click [Advance options] in the above dialog box to open up options for changing the quality/Kb. Gimp2.0 used to show directly all the available options while Gimp2.2x hides it.
