Old 19-06-2005, 12:54 AM   #1 (permalink)
harmax's Avatar
Default WHATS THE difference (SRPMS / i386) ????????????????????????
when i was about to download fc4 from a mirror the ftp site gave me 4 options as shown in the picture
the last two i figured out is not for me
so whats the diff b/w SRPMS and i386 , which is better??
somebody please elaborate
thnx in adv
WORK EXPANDS TO FILL THE TIME NEEDED FOR ITS COMPLETION
-------- PARKINSON\'S LAW
harmax is offline
Old 19-06-2005, 07:13 AM   #2 (permalink)
gauravnawani's Avatar
SRPM stands for Source RPM. It is basically only sourceRPM file and when you install it and it gets installed like an RPM file, but it goes into a predefined directory from where you compile the sources it extracts, just like any *.tar.gz or other source files.
i386 stands for Intel 32 plateform of processors and like p3 p4 and that also includes athlon, athlonxp.
Just go to i386 and download the iso for it if you have any of those processors.
BTW the CD you will generate from those ISO's will still have few packages in SRPM. But all you need to worry right now is i386&RPM.
Blender India forums
http://www.bestfreeforums.com/forums/blenderindia.html
gauravnawani is offline
- by Anorion
- by ax3
