Old 14-06-2005, 04:31 PM   #1 (permalink)
Default One PHP MYSQL problem
Hi Guys,
now here is the prob,
I am using WAMP 5 server which concludes php5 & MYSQL 4.1
now when i change to mysql directory & then to bin
but when i try to connect through "mysql -p root -p <enter> password"
then it's throwing error, that is
host "localhost" is not allowed to connect to this MYSQL server
and all my Database connections are not working
can some one please explain this in details.................
Music is like Sex, The more you get, the more you want.
demoninside is offline
Old 14-06-2005, 07:45 PM   #2 (permalink)
FooBar Guy
GNUrag's Avatar
What does the relevant entry in /etc/mysql/my.conf say?
Have you blocked anything there?
http://web.gnuer.org
GNUrag is offline
Old 15-06-2005, 06:18 AM   #3 (permalink)
harmax's Avatar
try this
mysql -u root -p<password><enter>
yes no space b/w -p and password
about localhost : when try mysql-admin it does not allow u to connect to localhost but it insists on either using
localhost.localdomain
[or]
127.0.0.1
and by the way did u create proper users and permissions . the manual that comes along mysql tar archive clearly explains 'em
hope this helps u
WORK EXPANDS TO FILL THE TIME NEEDED FOR ITS COMPLETION
-------- PARKINSON\'S LAW
harmax is offline
Old 15-06-2005, 04:01 PM   #4 (permalink)
i just make it working,
exactly my system was corrupted, and mysqld.exe was not working so i reinstalled it and now it's working
Old 21-06-2005, 12:26 AM   #5 (permalink)
hafees's Avatar
Ey ! harmAx man you copied my avatar!
hafees is offline
