Old 28-03-2009, 09:50 AM   #1 (permalink)
Dark Star's Avatar
Default Help mounting NTFS
Hi
I closed my Vista abruptly now I can't boot in Vista its corrupted .. and I have 3 Linux installed.. I have few important file in NTFS patrtition.. I tried force mount but I can get it done..
Please help me
   Device Boot      Start         End      Blocks   Id  System
/dev/sda1   *           1        5421    43542528    7  HPFS/NTFS
/dev/sda2            5422        6173     6040440   82  Linux swap / Solaris
/dev/sda3            6174       10507    34812855   83  Linux
/dev/sda4           10508       77825   540731835    5  Extended
/dev/sda5           10508       29629   153597433+  83  Linux
/dev/sda6           29630       54870   202748301   83  Linux
/dev/sda7           54871       77825   184386006   83  Linux
[root@localhost ~]# ntfs-3g /dev/sda1 /mnt/windows/C  -o force
ntfs-3g-mount: failed to access mountpoint /mnt/windows/C: No such file or directory
Regards
Me Myself and My Tux Blog :- http://tuxenclave.wordpress.com/
Dark Star is offline
Old 28-03-2009, 11:30 AM   #2 (permalink)
Dark Star's Avatar
Default Re: Help mounting NTFS
Done Ubuntu LIVE CD did the trick .. Taken the back up.. wil repair the vista system afterwards
Old 28-03-2009, 12:05 PM   #3 (permalink)
you are doing it wrong, there is no directory called C.
Faun is offline
Old 28-03-2009, 04:49 PM   #4 (permalink)
Married!
Rahim's Avatar
You have to ceate a mount point "/mnt/windows/C" first. But you solved your problem already
|| GNU/Linux User || PCLOS KDE 4.6 || 17" DELL Studio ||
topdocumentaryfilms.com
Rahim is offline
